Initializing SoftwareSerial after instantiation, if needed
I am creating an Arduino library to retrieve ranging data from the LV-MaxSonar-EZ1. The data can be gotten using Pulse Width, Analog, and Serial (inverted RS232). The library will create a connection to the sensor based on the constructor parameters. I am using SofwareSerial to make the serial connection, and it works, but I would like to not instantiate a SoftwareSerial object if the library is being used in the Pulse Width or Analog modes.
The following code will get the serial data successfully:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 11, true);
  Serial.begin(57600);
  while (!Serial) { ; }
  mySerial.begin(9600);
  while (!mySerial.isListening()) { ; }
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
This returns the serial ranging data of the form Rxxx, where xxx is the range in inches:
R009
R008
R009
R010
R011
R012
R013
R074
R074
R074
R013
R074
R012
R010
R010
R008
I was trying to use a pointer for later instantiation of SoftwareSerial, but it only returns white space in the console, here is the code:
SoftwareSerial* mySerial;
  mySerial = &SoftwareSerial(7, 11, true);
  mySerial->begin(9600);
  while (!mySerial->isListening()) { ; }
  if (mySerial->available())
    Serial.write(mySerial->read());
    mySerial->write(Serial.read());
I have tried in my library to use a static variable, a null pointer, and several other fruitless methods. What other way can I have the SoftwareSerial object be created only when using the serial mode?
The constructor will be invoked, and will then go out of scope, making the memory it occupies available again.
    mySerial = new SoftwareSerial(7, 11, true);
This way, the memory allocated will remain until mySerial is deleted.
First of all, there are an issue with this code:
I don't think this is the way to test if the serial port is available. If the Serial object was created successfully (should be the case), it does nothing. If it wasn't, it could be an infinite loop.
For the dynamic creation of an object, use the new keyword instead of a &. New will return a pointer to an object.
Be aware that using dynamic memory allocation in a system with very little RAM can lead to the system running out of RAM. Memory use can become inefficient.In a lot of cases, you are better off using static allocation.
By the way, if you want to make the decision at compile time, you can use #define and #ifdef
Pieter
pbrouwer, I derived the while loop from this link: if(Serial) - Arduino Reference
Thank you both for your help. The following code now brings back MaxSonar-EZ1 data via serial, while initializing SoftwareSerial after instantiation. My library still has a lot of kinks to work out, but the proof of concept sketch works.
I have the library working now. It will read data via Serial, Analog, or Pulse Width from the MaxSonar-EZ1 sensor. Here is a link to the repository:
