Initializing structs within a class
I am developing a data structure that can describe various aspects of controlling robots (e.g. managing motors, checking distances, turning LEDs on and off). I have a class (CommandDefinitions) that defines the structure and I am having problems getting it to compile.
  1. I get these compile errors that I cannot seem to fix:
    Error undefined reference to CommandDefintions showDigitalCommands() D:\Users\Bob.ObigOne\Documents\Arduino\CommandData\CommandData.ino 40
    Error undefined reference to CommandDefintions showLEDCommands() D:\Users\Bob.ObigOne\Documents\Arduino\CommandData\CommandData.ino 36
    Error undefined reference to CommandDefintions showMotorCommands() D:\Users\Bob.ObigOne\Documents\Arduino\CommandData\CommandData.ino 32
All source code is attached and I welcome any suggested improvements to my code.
CommandData.ino (939 Bytes)
CommandDefinitions.cpp (3.78 KB)
CommandDefinitions.h (2.13 KB)
*	This class defines commands that can be processed by processes that read
*	and executed commands arriving from Serial input, Software Serial input
*	and HC-05 Bluetooth input.
*	This file is designed to be expanded and extended. Each major consumer
*	of this code can focus on a specific subset of the commands and only
*	include that code; hence the #if compiler directives scattered throughout
*	this code.
*	Consuming clents need to identify the commands they want to implement
*	Using simple define statements:
*	#define SUPPORT_DIGITAL_MANAGEMENT		true
*	#define SUPPORT_ANALOG_MANAGEMENT		false
*	#define SUPPORT_LED_MANAGEMENT			true
*	#define SUPPORT_MOTOR_MANAGEMENT		true
*	#define SUPPORT_PAUSE_MANAGEMENT		false
*	#define SUPPORT_NAVIGATION_MANAGEMENT	false
// CommandDefinitions.h
#ifndef _COMMANDDEFINITIONS_h
#define _COMMANDDEFINITIONS_h
#if defined(ARDUINO) && ARDUINO >= 100
#include "arduino.h"
#else
#include "WProgram.h"
#endif
class CommandDefintions {
public:
	//	Constructor
	CommandDefintions();
	//	Initialize command structures
	void init();
	//	Templates
	struct operation {
		char *name;
		char code;
	struct selector {
		char *name;
		char code;
	struct action {
		char *name;
		char code;
#if SUPPORT_DIGITAL_MANAGEMENT
 *	Digital Management supports setting and reading digital pins 0..13
	struct digitalCommand {
		operation opr;
		selector sel[14];
		action act[3];
	struct digitalCommand *pin;
	void showDigitalCommands();
#endif
#if SUPPORT_ANALOG_MANAGEMENT
#endif
#if SUPPORT_LED_MANAGEMENT
	struct ledCommand {
		operation opr;
		selector sel[3];
		action act[3];
	struct ledCommand *led;
	void showLEDCommands();
#endif
#if SUPPORT_MOTOR_MANAGEMENT
	struct motorCommand {
		operation opr;
		selector sel[3];
		action act[5];
	motorCommand *motor;
	void showMotorCommands();
#endif
#if SUPPORT_PAUSE_MANAGEMENT
#endif
#if SUPPORT_NAVIGATION_MANAGEMENT
#endif
private:
#endif
#include "CommandDefinitions.h"
CommandDefintions::CommandDefintions() {
void CommandDefintions::init() {
	initializeMotorCommands();
#endif
	initializeLEDCommands();
#endif
	initializeDigitalCommands();
#endif
void initializeMotorCommands() {
	Serial.println("Motor Operation");
	motor->opr = { (char *) "MOTOR",'M' };
	Serial.println("Motor Selectors");
	motor->sel[0] = { (char *) "LEFT", 'L' };
	motor->sel[1] = { (char *) "RIGHT", 'R' };
	motor->sel[2] = { (char *) "BOTH", 'B' };
	Serial.println("Motor Actions");
	motor->act[0] = { (char *) "FORWARD", 'F' };
	motor->act[1] = { (char *) "BACKWARD", 'B' },
		motor->act[2] = { (char *) "STOP",'S' };
	motor->act[3] = { (char *) "FASTER",'+' };
	motor->act[4] = { (char *) "SLOWER", '-' };
	Serial.println("Motor Initialization completed");
void CommandDefintions::showMotorCommands() {
	int selectorCount = sizeof(motor->sel) / sizeof(motor->sel[0]);
	int actionCount = sizeof(motor->act) / sizeof(motor->act[0]);
	Serial.print("Motor Command: ");
	Serial.print(motor->opr.name);
	Serial.print("(");
	Serial.print(motor->opr.code);
	Serial.print(") has ");
	Serial.print(selectorCount);
	Serial.print(" selectors and ");
	Serial.print(actionCount);
	Serial.println(" actions:");
	Serial.print("SEL:");
	for (int i = 0; i < selectorCount; i++) {
		Serial.print(motor->sel[i].name);
		Serial.print("(");
		Serial.print(motor->sel[i].code);
		Serial.print(") ");
	Serial.print("ACT:");
	for (int i = 0; i < actionCount; i++) {
		Serial.println(motor->act[i].name);
		Serial.print("(");
		Serial.print(motor->act[i].code);
		Serial.print(") ");
#endif
void initializeLEDCommands() {
	led->opr = { (char *) "LED", 'L' };
	led->sel[0] = { (char *) "RED", 'R' };
	led->sel[1] = { (char *) "YELLOW", 'Y' };
	led->sel[2] = { (char *) "GREEN", 'G'};
	led->act[0] = { (char *) "ON",'+' };
	led->act[1] = { (char *) "OFF", '-' };
void CommandDefintions::showLEDCommands() {
	Serial.print(led->opr.name);
	Serial.print(" ");
	int selectorCount = sizeof(led->sel) / sizeof(led->sel[0]);
		Serial.println(led->sel[i].name);
	int actionCount = sizeof(led->act) / sizeof(led->act[0]);
		Serial.println(led->act[i].name);
#endif
void initializeDigitalCommands() {
	pin->opr.name = { (char *) "D_PIN", 'D' };
	pin->sel[0] = { (char *) "D0", char(0) };
	pin->sel[1] = { (char *) "D1", char(1) };
	pin->sel[2] = { (char *) "D2", char(2) };
	pin->sel[3] = { (char *) "D3", char(3) };
	pin->sel[4] = { (char *) "D4", char(4) };
	pin->sel[5] = { (char *) "D5", char(5) };
	pin->sel[5] = { (char *) "D6", char(6) };
	pin->sel[5] = { (char *) "D7", char(7) };
	pin->sel[5] = { (char *) "D8", char(8) };
	pin->sel[5] = { (char *) "D9", char(9) };
	pin->sel[5] = { (char *) "D10", char(10) };
	pin->sel[5] = { (char *) "D11", char(11) };
	pin->sel[5] = { (char *) "D12", char(12) };
	pin->sel[5] = { (char *) "D13", char(13) };
	pin->act[0] = { (char *) "ON", '+' };
	pin->act[1] = { (char *) "ON", '+' };
	pin->act[2] = { (char *) "STATUE", '+' };
void CommandDefintions::showDigitalCommands() {
	Serial.print(pin->opr.name);
	Serial.print(" ");
	int selectorCount = sizeof(pin->sel) / sizeof(pin->sel[0]);
		Serial.println(pin->sel[i].name);
	int actionCount = sizeof(pin->act) / sizeof(pin->act[0]);
		Serial.println(pin->act[i].name);
#endif
CommandData.ino
//		CAPABILITY						SUPPORT
#define PROCESS_SERIAL_COMMANDS			false
#define PROCESS_SSP_COMMANDS			false
#if PROCESS_SERIAL_COMMANDS
#endif
#if PROCESS_PROCESS_COMMANDS
#endif
CommandDefintions *commands;
	commands = new CommandDefintions();
	commands->init();
	commands->showMotorCommands();
#endif
	commands->showLEDCommands();
#endif
	commands->showDigitalCommands();
#endif
Try changing these #if SUPPORT_DIGITAL_MANAGEMENT to #ifdef SUPPORT_DIGITAL_MANAGEMENT or #if defined SUPPORT_DIGITAL_MANAGEMENT
It is either 'if SUPPORT_DIGITAL_MANAGEMENT' (C code) or '#ifdef SUPPORT_DIGITAL_MANAGEMENT' (pre-pocessor)
if SUPPORT_DIGITAL_MANAGEMENT just doesn't look right to me.
The preprocessor does know about true or false. Use 1 and 0 instead.
That looks just fine to the preprocessor – of course depending on how SUPPORT_DIGITAL_MANAGEMENT is #defined; undefined is OK, empty definition is not.
