Initilizition Failed
Hi everyone..
I am newbie in this area and recently making a project using arduino. I have problem in using SD function as I always get "Initilization Failed" for the SD card example. I am using Arduino UNO and sparkfun MicroSD sheild. For the software, I am using Arduino Version 1.6.5. I had tried few suggestion from this forum:
  1. They suggested to download new library which is SdFat library from https://github.com/greiman/SdFat
Unfortunately, when I was trying to verify the code, I got error as below
SdInfo.ino:5:19: fatal error: SdFat.h: No such file or directory compilation terminated. Error compiling.
  1. Based on http://forum.arduino.cc/index.php?topic=240330.0 I had tried the code and as result I got
errorCode: 1 errorData: 0 Which means there is hardware problem or card problem
  1. Then, I tried with new SD card but still not working.
I really really really hope anyone may help me to solve this problem.. :( :( :( Thank you
The assumption is that you will install the library, too, in the proper location. Silly idiots making such assumptions without documenting them.
I really, really, really hope that you'll post your code.
