Hello
For some time critical issues I included inline assembler code into an Arduino sketch. Looking into the resulting assembler code I discovered, that the LSL (Logical Shift Left) instruction in the asm statement was translated to an ADD instruction in the assembler listing. The instruction LSR (Logical Shift Right) was translated correctly.
You can reproduce it by the following sketch:
Inline assembler translates LSL (Logical Shift RLeft) to wrong code.
sentido, 19.12.09
Windows XP Professional
arduino-0017
int ledPin = 13;
pinMode(ledPin, OUTPUT);
// Just do something, otherwise the compiler removes everything while optimizing
digitalWrite(ledPin, HIGH); // set the LED on
// to find location in assembler output easily
asm volatile("nop");
// BUG: lsl (Logical Shift Left) produces same output as add,
// lsr (Logical Shift Right) is translated correctly
asm volatile("lsl r3"); // 33 0c add r3, r3 ;-> WRONG!!!
asm volatile("add r3,r3"); // 33 0c add r3, r3 ;-> correct
asm volatile("lsr r3"); // 36 94 lsr r3 ;-> correct
// The problem is the same with any other register
In the applet subdirectory execute e.g. "avr-objdump -d LSL_bug.cpp.elf > asm.txt" if you called the sketch LSL_bug and have a look into asm.txt.
Any hints on how to fix it, work around or whom to ask?
sentido
