Since the inheritance path changed, oh, back before arduino-0020... (6 month ago, eh?)
I'm not really enough of a C++ programmer to know if that will work, though.
You'd probably be better off with a newer version of the library: Streaming | Arduiniana
It's claimed to be 1.0 compatible for a while (probably since shortly after 1.0. We're at 1.6.7+ now...)
The multi line template is causing the error. You can it by changing it to:
template<class T> inline Print &operator <<(Print &obj, T arg) // no-cost stream operator as described at http://arduiniana.org/libraries/streaming/
obj.print(arg);
return obj;
Automatic generation of function prototypes was changed to a new program, arduino-builder starting with Arduino IDE 1.6.6. In some cases this fails to correctly handle code that worked with the previous versions of the IDE. This issue was reported at Multiline templates not supported in sketch · Issue #43 · arduino/arduino-builder · GitHub but the developer decided that it would not be fixed and that only single line templates will be handled correctly.
pert:
obj.print(arg);
return obj;
Automatic generation of function prototypes was changed to a new program, arduino-builder starting with Arduino IDE 1.6.6. In some cases this fails to correctly handle code that worked with the previous versions of the IDE. This issue was reported at https://github.com/arduino/arduino-builder/issues/43 but the developer decided that it would not be fixed and that only single line templates will be handled correctly.
Thank you very much for this, it did indeed compile with this change!
