Hi
I have a project where I need to run 12v thru a few relays. I also need to be able to check the status, so basicaly I need a full input/output
I can only use RJ-45 (8 pins) between the two places. So I was thinking of using 1 pin for 12v, 1 pin for GND so I have 6 cables left.
When I use Shift Register, I need 4 cables for the input and 4 for the output... So this makes 8 only for the data plus 12v + GND...
Is there a way to optimize this so that I can send all this thru 8 pins??
I saw a few person that said to use shift register, only with 3 pins? Maybe?
Thanks!
Steven
Sure, 2 shift registers even: Clk, Data Out, Latch-Out, and same Clock, Latch-In, Data In.
74HC595 for output if you don't to drive much current,
74HC165 for input.
CrossRoads:
74HC165 for input.
Thanks for the quick reply
Just to be sure, you are sharing the same pin for the clock only or the 2 others also?
So it makes 5 pins: clock, latch in, data in, latch out, data out?
Thanks!
CrossRoads:
Clock only.
Awesome, thanks so much!!!
