Hi guys,
I’m pretty new to Arduino, I’ve been programming another AVR boards for some time.
I have a problem with Input Capture, there’s probably some mistake in the code but it’s already taken 12h of my life…
I need to decode encoder 10bit PWM output signal. It’s about 1kHz with pulses beginning from 1us. I work with Arduino MEGA2560.
Because pulseIn() can measure pulses from 10us, I have to use Input Capture. I’ve written some test code just to check if it works before plugging in the encoder. I try to measure both t_on and t_off as in the link above and what I get is proper value of t_off and completely random value of t_on. I have no idea what I’m doing wrong.
I use PWM signal generated with TIMER3 - 1kHz wave with 50% duty cycle. With TIMER4 setting as in the code I should get t_on=t_off=1000.
Moreover, I’ve read much about pulse width measuring. In general people say that it would be hard to measure 1us width pulse. I’m aware of that but I’d like this code to work properly anyway - for this example t_on=t_off=500us. Do you have any advice for me? How should I decode signal from the encoder? Is Input Capture good idea or should I try something else? I need position update of about 200Hz.
Thanks in advance for your help!
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define MEASUREMENT_BEGIN 0
#define AFTER_1_INTERRUPT 1
#define T_ON_AVAILABLE 2
#define MEASUREMENT_AVAILABLE 3
volatile uint8_t Control_var;
volatile uint16_t LastCapture;
volatile uint16_t t_on;
volatile uint16_t t_off;
volatile float position;
void encoder_measure_init()
DDRL &= ~(1<<PL0); //encoder input
PORTL |= (1<<PL0); //pin pull-up
TCCR4A = 0; //TIMER4 normal mode
TCCR4B = 0;
TCCR4C = 0; //TIMER4 normal mode
TCCR4B |= (1<<CS41); //prescaler -> Timer4 / 8
TCCR4B |= (1<<ICES4); //rising edge
void PWM_init()
DDRE |= (1<<PE3); //set as an output
TCCR3A = 0;
TCCR3B = 0;
TCCR3C = 0;
TCCR3A |= (1<<WGM31); //setting Fast PWM mode, count up to ICR3
TCCR3B |= (1<<WGM32) | (1<<WGM33); //setting Fast PWM mode, count up to ICR3
TCCR3A |= (1<<COM3A1); //set OC3A at BOTTOM, clear on OCR3A
TCCR3B |= (1<<CS30); //prescaler -> Timer3 / 1
ICR3 = 15999; //I want to get 1000Hz frequency. F_CPU= 16MHz
OCR3A = 7999; //I should get 50% duty cycle
//interrupt procedure
ISR(TIMER4_CAPT_vect)
if( Control_var == AFTER_1_INTERRUPT )
t_on = ICR4 - LastCapture;
if( Control_var == T_ON_AVAILABLE )
TIMSK4 &= ~(1<<ICIE4); //turn off capture interrupt
t_off = ICR4 - LastCapture;
LastCapture = ICR4;
Control_var++;
TCCR4B ^= (1<<ICES4); //toggle the edge
float get_position()
uint16_t pos;
Control_var = MEASUREMENT_BEGIN;
TCNT4 = 0; //not to let the register overflow
TCCR4B |= (1<<ICES4); //set rising edge
TIMSK4 |= (1<<ICIE4); //turn on capture interrupt
while(Control_var != MEASUREMENT_AVAILABLE) {}
position = ( ((float)t_on * 1026.) / ((float)t_on + (float)t_off) ) - 1.;
if (pos == 1024) pos = 1023;
return pos;
encoder_measure_init();
PWM_init();
sei();
position = get_position();
//Serial.write((int)position&0xff);
//Serial.write((int)position>>8);
Serial.write(t_on&0xff);
Serial.write(t_on>>8);
Serial.write(t_off&0xff);
Serial.write(t_off>>8);
Serial.write(0);
_delay_ms(1000);
