input data on array
i have this code
const int pump_count = 2;
const uint8_t pump_pins[pump_count] = {5, 6,};
const uint32_t pump_half_periods[pump_count] = {1000, 2000};
uint8_t pump_states[pump_count];  // LOW or HIGH
uint32_t pump_last_actuations[pump_count];  // time in ms
    for (int i = 0; i < pump_count; i++) {
        pinMode(pump_pins[i], OUTPUT);
    unsigned long now = millis();
        if (now - pump_last_actuations[i] >= pump_half_periods[i]) {
            pump_states[i] = (pump_states[i] == LOW) ? HIGH : LOW;
            digitalWrite(pump_pins[i], pump_states[i]);
            pump_last_actuations[i] = now;
     Serial.println(now);
but i want to change this
this is a static input i want to another input from my calculation how can i store my calculation on to this array ? thx for helping me
Remove the 'const' keyword.
aarg:
how about syntax for filling a new one ?
const keyword should only use when you do not want to change the value. When you want to change the value, you need to remove that keyword
Nautilius:
  pump_half_periods[0] = 1492ul;  // The 'ul' means the constant is an unsigned long
