Input latency timer w/ Mouse.h
I made a project to count input latency between mouse input and output on PC monitor by using Arduino Micro and photo transistor. So I tried two approaches: 1. Mouse.click(), 2. Mouse.move(). Both works, but I get different results, with move command I get average latency 19,75ms, with click command it’s 40ms. My question would be: is it games fault of different results on input, or is it my project handling move and click commands differently?
Code w/ move:
#include <Mouse.h>
#include <SevSeg.h>
SevSeg sevseg; //Instantiate a seven segment object
unsigned long previousMicros = 0;
const int ledPin = 13;
const int buttonPin = 0;
const long interval = 5000000;
int analogPin = 0;
int val = 0;
int buttonState = 0;
unsigned long lag = 0;
unsigned long lag2;
int state = 0;
unsigned long var2 = 0;
void setup(){
  Mouse.begin();
  byte numDigits = 4;
  byte digitPins[] = {8, 11, 3, 12};
  byte segmentPins[] = {7, 6, 4, 2, 1, 9, 10, 5};
  bool resistorsOnSegments = true; // 'false' means resistors are on digit pins
  byte hardwareConfig = COMMON_CATHODE; // See README.md for options
  sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT_PULLUP);
void loop(){
  unsigned long currentMicros = micros();
  val = analogRead(analogPin);
  buttonState = digitalRead(buttonPin);
  if (buttonState == LOW){
    previousMicros = currentMicros;
    state = 1;
  if (currentMicros - previousMicros >= interval && state == 1){
    Mouse.move(50, 0, 0);
    digitalWrite(ledPin, HIGH);
    state = 2;
  if (val <= 980 && state == 2){
    lag = currentMicros - previousMicros;
    state = 3;
    digitalWrite(ledPin, LOW);
    Mouse.move(-50, 0, 0);
  if (state == 3){
    if (lag >=1000000){
      lag2 = lag /1000;
      sevseg.setNumber(lag2);
    if (lag < 1000000){
      lag2 = lag / 100;
      sevseg.setNumber(lag2, 1);
  sevseg.refreshDisplay();
Code w/ click:
#include <Mouse.h>
#include <SevSeg.h>
int analogPin = 0;
int val = 0;
unsigned long lag2;
int state = 0;
void setup(){
  Mouse.begin();
  byte numDigits = 4;
void loop(){
    state = 1;
    Mouse.click();
    state = 2;
    state = 3;
  if (state == 3){
    if (lag >=1000000){
      lag2 = lag /1000;
    if (lag < 1000000){
      lag2 = lag / 100;
A mouse driver has to wait for mouse down then mouse up for a single click. Eventually a debounce feature delays the recognition of a single click, and/or waits to distinguish between single and double clicks.
How did you write the reaction on the PC monitor? Which OS?
DrDiettrich:
Oh thanks that explains a lot. Windows 10. I attached photo transistor onto monitor screen, which reacts to brightness. In case of mouse move I just place it on black spot, but very near bright spot, then it moves and photo transistor reacts. In case of mouse click I place photo transistor at end of a gun where fire happens. So I suppose better use move command as it doesn't have any waiting for debounce and etc.
Mouse click:
Mouse move:
For the click you can react on WM_LBUTTONDOWN or on WM_LBUTTONUP, with different timing.
Also note that screen update has lowest priority, occurs only if everything else has been handled.
