Hello guys,
I am trying to write some line of code for a project I am working on.
The project is a multi-HID button box based on arduino leo and input shift registers to increase the number of inputs.
When a button is pressed, I want it to emulate a joy button press or a key press depending on the value contained in the dedicated array (keybtn[]).
The pronlem is: if I assign joypad button presses, everithing is ok. If I start assigning key presses, only the one assigned to keybtn[0] works, the other keys being ignored.
Could someone take a look at my mess and give feedback?
#include <SPI.h>
#include <Joystick.h>
#include <Keyboard.h>
#define REG_SWITCH 24 //number of switches and buttons
//SHIFT REGISTERS
const byte IN_REG = 3; //number of input shift registers
//PINOUT
const byte inLatchPin = 9; //input registers latch pin
//SPI MISO 14
//SPI MOSI 16
//SPI SCLK 15
//inputs variables
byte imask;
byte iState;
int debounceTime = 40; //ms
byte stateByte[IN_REG];
byte prevStateByte[IN_REG];
unsigned long debounce [REG_SWITCH];
//Numbers up to 23 are emulated as joypad buttons, numbers >= 24 are emulated as key presses (ASCII)
//https://www.arduino.cc/reference/en/language/functions/usb/keyboard/keyboardmodifiers/
const byte keybtn[REG_SWITCH] = {177 /*ESC*/, 176 /*RETURN*/, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14, 15,
16, 17, 18, 19, 20, 21, 22, 23};
//JOYSTICK DEFINITION
//X and Y rotation are L and R triggers (separate axis).
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, REG_SWITCH, 0, //joy type, button count, hatswitch count
false, false, false, // X, Y, Z axis
false, false, false, // X, Y, Z rotation
false, false, //rudder, throttle
false, false, false); //accelerator, brake, steering
void setup (){
pinMode (inLatchPin, OUTPUT);
digitalWrite (inLatchPin, HIGH);
//initialize debounce
for (int a = 0; a < REG_SWITCH; a++){
debounce[a] = millis();
SPI.begin ();//start SPI
Joystick.begin();//Initialize Joystick
Keyboard.begin();//Initialize keyboard
} // end of setup
void loop (){
InRegPulse();
InRegRead();
InRegHandle();
} // end of loop
void InRegHandle(){ //Handle registry inputs (74HC165)
for (int a = 0; a < IN_REG; a++){
imask = 0b00000001;
for (int i = 0; i < 8; i++){
iState = stateByte[a] & imask;
if (millis()- debounce[i+(a*8)] > debounceTime && iState != (prevStateByte[a] & imask)){
debounce[i+(a*8)] = millis();
if(keybtn[i+(a*8)] < REG_SWITCH){//JOYPAD
Joystick.setButton(keybtn[i+(a*8)], iState);
delay(8);
else{//KEYBOARD
if (iState == 1){//BUTTON PRESSED
Keyboard.write(keybtn[i+(a*8)]);
delay(50);
imask <<= 1; //move to the next bit
prevStateByte[a] = stateByte[a];
void InRegPulse(){ // pulse the parallel load latch to send bytes serially
digitalWrite (inLatchPin, LOW);
//delayMicroseconds(5);
void InRegRead(){ //read inputs states from registers
stateByte[a] = SPI.transfer (0);//"0" is dummy: you could have any value in
