Hello, I want help regarding my project.
Here's the situation... I want to calculate k from this formula "k = QL/AΔT" where 'ΔT' is variable and all others are constant.
How can I program Arduino so that I input value of 'ΔT' and get the value of 'k' displayed on the LCD display or seven segment display?? Please help.
Robin2
2
float calcK( float deltaT) {
float k = XXX * deltaT;
return k
This assumes that you use a calculator to work out the constant value QL/A and enter the result where I have XXX
And you use the function like this
myResult = calcK( YYY);
where YYY is the value of deltaT that you want to use
...R
Thank you for your reply
'ΔT' is one single term for temperature difference.
Robin2
4
rishi13:
I know. I hope that is what my code snippet reflects.
...R
Yes... Thank you so much that was really helpful
(y)
