Hello,
I dont think the topicname is a good one, but I cant think a better one.
I can rotate a Dynamixel through ethernet with the ethernet shield.
Now I want to change the speed, position and PID values through ethernet.
I think it can work by:
Example speed
Speed Value -> input field -> into string -> StrContains(HTTP_req, "Speed-value") -> read string speed-value convert to int value ->
Dynamixel.servo(SERVO_ID,0x3FF,speed_val); // Dynamixel go to IN-position
I rewrite the code this Ethernet tutorial: Arduino Webserver Input and Output
I tried:
Save input values into string and than read them in the arduino sketch with:
if (StrContains(HTTP_req, "speed")) {
speed1 = StrContains(HTTP_req, "speed")
Dynamixel.servo(SERVO_ID,0x3FF,speed1);
Without any luck.
Does someone know a way to put those values into the StrContains(HTTP_req, "speed") string and read the value into the arduino sketch?
Thanks in advance.
arduino_sketch.txt (9.9 KB)
sd_card_htmlindex.txt (7.06 KB)
