Inputting more than 360 degrees for an encoder
For the encoder target position can i input more than 360 degrees so the motor will
turn more than 360 degrees?
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
#include <RCSwitch.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
const int encoderPinA = 2;
const int encoderPinB = 3;
volatile int encoderPos = 0;
int encoderPosTarget = 0;
bool direction = true;
const int rfReceiverPin = 11; // RF Receiver connected to pin 11
RCSwitch mySwitch = RCSwitch(); // Create an instance of RCSwitch
AFMS.begin();
pinMode(encoderPinA, INPUT_PULLUP);
pinMode(encoderPinB, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(encoderPinA), encoder_ISR, CHANGE);
mySwitch.enableReceive(rfReceiverPin); // Enable the receiver on pin 11
if (mySwitch.available()) {
unsigned long receivedValue = mySwitch.getReceivedValue();
handleKeyFobPress(receivedValue);
mySwitch.resetAvailable();
void encoder_ISR() {
if (digitalRead(encoderPinA) == digitalRead(encoderPinB)) {
encoderPos++;
encoderPos--;
void rotateToPosition(int targetPosition) {
if (encoderPos < targetPosition) {
direction = true;
myMotor->run(FORWARD);
myMotor->setSpeed(255); // Adjust speed as needed (0 to 255)
direction = false;
myMotor->run(BACKWARD);
while (encoderPos != targetPosition) {
if (direction && encoderPos >= targetPosition) {
myMotor->run(RELEASE);
if (!direction && encoderPos <= targetPosition) {
void handleKeyFobPress(unsigned long receivedValue) {
if (receivedValue == /* code for your specific key fob press */) {
if (direction) {
encoderPosTarget = 180; // Rotate to 180 degrees for example
encoderPosTarget = 0; // Rotate back to 0 degrees
rotateToPosition(encoderPosTarget);
direction = !direction; // Toggle direction flag
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post a link to the datasheet.
Input where, when?
Yes.
Please edit your post to add code tags.
Encoder positions are counted in encoder steps, which are rarely degrees.
Did you copy this code from somewhere? The comments would be valid ONLY if the encoder were an absolute angle shaft encoder, with 360 steps per revolution.
