Inquiry with Regards to Control / Connection to Peristaltic Pump with Flex
Hello,
I am new to this forum and was looking for some guidance with regards to controlling a peristaltic pump with Arduino.
I am hoping to use the RP-TX pump from Takasago (link: https://www.takasago-fluidics.com/p/pump/s/transfer/RP-TX) but have noticed that the connection to the motor is through a flex (not standard motor connections). I was wondering if anyone has experience with connecting to a pump motor similar to this and would be able to provide any tips, best-practices or safety provisions.
Any information you have would be greatly appreciated!
I have attached a picture of the pump with the flex visible.
Thank you very much in advance!
Best wishes,
Sara
Have You looked at other pumps being more easy to connect with?
If it were me I would probably solder to the connector if I did not have the socket. Sockets are available and in the long run save you time and money. You can contact the manufacturer for the correct connector or socket.
