Code used :
#include "SPI.h"
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9340.h"
#include <Wire.h>
#include "ds3231.h"
#define BUFF_MAX 128
uint8_t time[8];
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
#if defined(__SAM3X8E__)
#undef __FlashStringHelper::F(string_literal)
#define F(string_literal) string_literal
#endif
// These are the pins used for the arduino pro mini
#define _sclk 13
#define _miso 12
#define _mosi 11
#define _cs 10
#define _dc 9
#define _rst 8
// Using software SPI is really not suggested, its incredibly slow
//Adafruit_ILI9340 tft = Adafruit_ILI9340(_cs, _dc, _mosi, _sclk, _rst, _miso);
// Use hardware SPI
Adafruit_ILI9340 tft = Adafruit_ILI9340(_cs, _dc, _rst);
Serial.println("GET time");
tft.begin();
tft.fillScreen(ILI9340_BLUE);
tft.setRotation(3);
Wire.begin();
DS3231_init(DS3231_INTCN);
memset(recv, 0, BUFF_MAX);
//TIME SETUP comment back after uploading
//Serial.println("Setting time");
//parse_cmd("T305121130032015",16); // TssmmhhWDDMMYYYY
void loop(void) {
char in;
char tempF[6];
float temperature;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if ((now - prev > interval) && (Serial.available() <= 0)) {
DS3231_get(&t); //Get time
parse_cmd("C",1);
temperature = DS3231_get_treg(); //Get temperature
dtostrf(temperature, 5, 1, tempF);
////////////////////// DATE ////////////////////////
tft.setTextColor(ILI9340_WHITE, ILI9340_BLUE);
tft.setTextSize(2);
tft.setCursor(15, 10);
tft.print("Today is");
tft.setCursor(115, 10);
printMonth(t.mon); // month
tft.setCursor(225, 10);
tft.print(t.mday);
tft.setCursor(260, 10);
tft.print(t.year); // year
tft.setTextSize(3);
tft.setCursor(35, 50);
tft.print("ARDUINO CLOCK");
///////////////////////// TIME //////////////////////
tft.setCursor(35, 100);
tft.setTextSize(5);
tft.print(t.hour);
tft.print(":");
tft.setCursor(125, 100);
if(t.min<10)
tft.print("0");
tft.print(t.min);
tft.print(":");
tft.setCursor(215, 100);
if(t.sec<10)
tft.print("0");
tft.print(t.sec);
//////////////////////// WEEK DAY ////////////////////
tft.setTextSize(3);
tft.setCursor(80, 150);
printWeekday(t.wday); // day name
//tft.print(t.wday);
tft.setTextSize(1);
tft.setCursor(100, 200);
tft.print("www.miniarduino.com");
/////////////////////// TEMPERATURE /////////////////
tft.setCursor(30, 220); //Go to last line of the LCD Screen
tft.setTextSize(2);
tft.print("Temperature: ");
tft.setCursor(180, 220);
tft.print(tempF);
//tft.print((char)223);
tft.print(" C");
prev = now;
if (Serial.available() > 0) {
in = Serial.read();
if ((in == 10 || in == 13) && (recv_size > 0)) {
parse_cmd(recv, recv_size);
recv_size = 0;
recv[0] = 0;
} else if (in < 48 || in > 122) {; // ignore ~[0-9A-Za-z]
} else if (recv_size > BUFF_MAX - 2) { // drop lines that are too long
// drop
recv_size = 0;
recv[0] = 0;
} else if (recv_size < BUFF_MAX - 2) {
recv[recv_size] = in;
recv[recv_size + 1] = 0;
recv_size += 1;
void parse_cmd(char *cmd, int cmdsize)
uint8_t i;
uint8_t reg_val;
struct ts t;
//snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
//Serial.print(buff);
// TssmmhhWDDMMYYYY aka set time
if (cmd[0] == 84 && cmdsize == 16) {
//T355720619112011
t.sec = inp2toi(cmd, 1);
t.min = inp2toi(cmd, 3);
t.hour = inp2toi(cmd, 5);
t.wday = inp2toi(cmd, 7);
t.mday = inp2toi(cmd, 8);
t.mon = inp2toi(cmd, 10);
t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
DS3231_set(t);
Serial.println("OK");
} else if (cmd[0] == 49 && cmdsize == 1) { // "1" get alarm 1
DS3231_get_a1(&buff[0], 59);
Serial.println(buff);
} else if (cmd[0] == 50 && cmdsize == 1) { // "2" get alarm 1
DS3231_get_a2(&buff[0], 59);
} else if (cmd[0] == 51 && cmdsize == 1) { // "3" get aging register
Serial.print("aging reg is ");
Serial.println(DS3231_get_aging(), DEC);
} else if (cmd[0] == 65 && cmdsize == 9) { // "A" set alarm 1
DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
//ASSMMHHDD
for (i = 0; i < 4; i++) {
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
boolean flags[5] = { 0, 0, 0, 0, 0 };
DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
} else if (cmd[0] == 66 && cmdsize == 7) { // "B" Set Alarm 2
DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
//BMMHHDD
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
boolean flags[5] = { 0, 0, 0, 0 };
DS3231_set_a2(time[0], time[1], time[2], flags);
} else if (cmd[0] == 67 && cmdsize == 1) { // "C" - get temperature register
Serial.print("temperature reg is ");
Serial.println(DS3231_get_treg(), DEC);
} else if (cmd[0] == 68 && cmdsize == 1) { // "D" - reset status register alarm flags
reg_val = DS3231_get_sreg();
reg_val &= B11111100;
DS3231_set_sreg(reg_val);
} else if (cmd[0] == 70 && cmdsize == 1) { // "F" - custom fct
reg_val = DS3231_get_addr(0x5);
Serial.print("orig ");
Serial.print(reg_val,DEC);
Serial.print("month is ");
Serial.println(bcdtodec(reg_val & 0x1F),DEC);
} else if (cmd[0] == 71 && cmdsize == 1) { // "G" - set aging status register
DS3231_set_aging(0);
} else if (cmd[0] == 83 && cmdsize == 1) { // "S" - get status register
Serial.print("status reg is ");
Serial.println(DS3231_get_sreg(), DEC);
Serial.print("unknown command prefix ");
Serial.println(cmd[0]);
Serial.println(cmd[0], DEC);
void printMonth(int month)
switch(month)
case 1: tft.print(" January ");break;
case 2: tft.print(" February ");break;
case 3: tft.print(" March ");break;
case 4: tft.print(" April ");break;
case 5: tft.print(" May ");break;
case 6: tft.print(" June ");break;
case 7: tft.print(" July ");break;
case 8: tft.print(" August ");break;
case 9: tft.print(" September ");break;
case 10: tft.print(" October ");break;
case 11: tft.print(" November ");break;
case 12: tft.print(" December ");break;
default: tft.print(" Error ");break;
void printWeekday(int wday)
switch(wday)
case 3: tft.print(" Monday ");break;
case 4: tft.print(" Tuesday ");break;
case 5: tft.print(" Wednesday ");break;
case 6: tft.print(" Thursday ");break;
case 7: tft.print(" Friday ");break;
case 1: tft.print(" Saturday ");break;
case 2: tft.print(" Sunday ");break;
