insert ultrasonic sensor values in mySQL with php and wifly
i want to input values in db mySQL with php. first, db is work well so i make php code below.
<?php
echo "insert_data_is_here\n";
error_reporting(E_ALL);
$con=mysqli_connect("ip","root", "pwd", "table");
if(mysqli_connect_errno($con))
	echo "Failed to connet to mySQL: " . mysqli_connect_error();
$distant = $_GET["distant"];
$sql = "insert in to db.data(distant) values(&distant)";
mysqli_query($con, $sql);
mysqli_close($con);
i have wifi module RN-171 for network and i find out it have compatible wifly library but it quite hard to find out proper example. however, i try to making arduino code is below.
#include <Arduino.h>
#include <OneWire.h>
#include <SoftwareSerial.h>
#include "WiFly.h"
#define SSID      "name"
#define KEY       "pwd"
#define AUTH      WIFLY_AUTH_WPA2_PSK
SoftwareSerial uart(2, 3);
WiFly wifly(&uart);
Client client("localhost",80);
int echoPin = 7;
int triggerPin = 8;
// for ultrasonic
  /* init */
  uart.begin(9600);     // WiFly UART Baud Rate: 9600
  // wait for initilization of wifly
  delay(3000);
  wifly.reset();
  Serial.println("Join " SSID );
  if(!wifly.isAssociated(SSID)) {
    if (wifly.join(SSID, KEY, AUTH)) {
      Serial.println("OK");
      Serial.println("Failed");
    wifly.save();
  /* ultranosic */
  pinMode(triggerPin, OUTPUT);
  pinMode(echoPin, INPUT);
  long duration, distance;
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration / 29 / 2;
  String str_distance = String(distance);
  Serial.print(str_distance + "cm");
  wifly.print("GET /insert_data.php?distant=" + str_distance + "\r\n");
  wifly.print("distant=");
  wifly.print(str_distance);
  if(wifly.available()) {
   // Serial.write(wifly.read());
  else {
    //Serial.println("UNAVAILABLE");
Do you have a question?
The first thing you need to understand is what the name "localhost" means.
Exactly where do you think the insert_data.php script is supposed to be executed? Is is REALLY possible to execute the script on that server? I DO NOT THINK SO!
