Inserting a bmp image
Arduino: 1.8.5 (Windows 10), Board: "Arduino Due (Programming Port)"
C:\Users\Johan Prinsloo\Documents\Arduino\BitmapExample\BitmapExample.ino: In function 'void setup()':
BitmapExample:41: error: invalid conversion from 'unsigned int' to 'unsigned int*' [-fpermissive]
drawBitmap(20, 20, 83, 83, ButtonPlay[0x1AE9]); // (0,0) where on the screen, (64,64) size of image, (conix_64x64) image name.
BitmapExample:52: error: initializing argument 5 of 'void drawBitmap(int, int, int, int, unsigned int*)' [-fpermissive]
void drawBitmap(int x, int y, int sx, int sy, unsigned int *data)
C:\Users\Johan Prinsloo\Documents\Arduino\BitmapExample\BitmapExample.ino: In function 'void loop()':
BitmapExample:48: error: too few arguments to function 'void drawBitmap(int, int, int, int, unsigned int*)'
drawBitmap();
C:\Users\Johan Prinsloo\Documents\Arduino\BitmapExample\BitmapExample.ino:52:6: note: declared here
exit status 1
option enabled in File -> Preferences.
/*DUE and 2.8" UNO TFT multi pin screen
#include <MCUFRIEND_kbv.h>
#include <Adafruit_GFX.h>
#include <TouchScreen.h>
MCUFRIEND_kbv tft;
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define LCD_RESET A4
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define LIGHTGREY 0xDEDB
#define GREY    0xCE79
extern unsigned int ButtonPlay[0x1AE9]; // "conix_[0x1000]" must match the name in the file.
  Serial.print("Starting...");
  tft.reset();
  uint16_t identifier = tft.readID();
  tft.begin(identifier);
  tft.setRotation(2);
  /* add in the functions to get your LCD started */
  drawBitmap();
  int tc = 0;
  for (int Y = 0; Y < sy; Y++)
    for (int X = 0; X < sx; X++)
      tft.drawPixel(X + x, Y + y, pgm_read_word(&data[tc]));
      if (tc < (sx * sy)) tc++;
Members
I received the error above when I compile this. Please help me to fix this. Thanks
Why do you want to pass the value of the item 1 place beyond your array?
I think you want to pass the pointer to your array
drawBitmap(20, 20, 83, 83, ButtonPlay);
PS drop the macros (define's), in C++ we have the saver alternative of const byte for pin definitions :wink:
sketch\BitmapExample.ino.cpp.o: In function `setup':
C:\Users\Johan Prinsloo\Documents\Arduino\BitmapExample/BitmapExample.ino:43: undefined reference to `ButtonPlay'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Due (Programming Port).
MCUFRIEND_kbv tft;
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
#define BLUE    0x001F
#define RED     0xF800
#define CYAN    0x07FF
#define GREY    0xCE79
  tft.reset();
  tft.setRotation(2);
  drawBitmap(20, 20, 83, 83, ButtonPlay); // (0,0) where on the screen, (64,64) size of image, (conix_64x64) image name.
//  drawBitmap();
  int tc = 0;
Thanks for the help. I changed the code but its still not compiling. Any suggestions?
Thanks
Any suggestions?
Yes. Look at your definition for ButtonPlay. See that extern keyword? That means that the variable will actually be defined in another file. What other file have you defined it in, and how is this file supposed to know that?
Thanks Paul.
The folder consists of 2 files: the .ino & a folder called 'bitmaps'. Inside 'bitmaps is the .c file for the 'buttonPlay'
How can I include the .c file into my code?
Thanks
Thanks Paul.
Ive relocated the .c file in the same folder as the .ino file.
Thanks for the help
