Inserting a variable for 'Servo.write'
I'm using the 'Servo.h' library to control multiple servos (for model railway signals). I've declared the servos as 'Servo Sig1' (then 2, 3 &4) and attached them to the relevant pins.
However, in the code when I want to write to a specific servo, I need the servo to be inserted as a variable dependent upon a button pressed.
i.e.
Sig1.write(angle) //where 'angle' is a variable
My problem is that if I try to insert the variable for the 'Sig1', I get an error. For example:
Sig(sigNo).write(angle)
How should I write this to allow me to insert any one of 4 servos (Sig1, Sig2, Sig3 or Sig4) without causing an error?
Use an array of Servo objects then you can refer to them by number like this
#include <Servo.h>
Servo servos[3];
const byte servoPins[] = {10, 11, 12};
  for (int s = 0 ; s < 3; s++)
    servos[s].attach(servoPins[s]);
  servos[0].write(180);
  servos[1].write(90);
  servos[2].write(0);
Use an array:
`Servo Sig[4];'
Then use Sig[0] in place of Sig1, Sig[1] in place of Sig2, Sig[2] in place of Sig3 and Sig[3] in place of Sig4. The number in the square brackets can be a variable.
Thanks very much - I can see how that would work so will give it a try.
Thank you very much - so simple really! I'll give it a whirl and update with the result.
