Inserting SD card causes a reboot?
I think that this is a hardware question? So here goes:
The attached is a schematic for a data logger that I have built. In (most) cases it works as I would wish.
However (isn’t there always!), when I insert my micro SD card, the ATMega reboots. Not what I would wish.
My first thoughts were Brownout? As the supply voltage drops as the card is powered up. Scoping the supplies (3v3 & 5v) shows no problems that I can detect. And bunging in larger & larger capacitors on the supply line have no effect.
I also understand that the SD Cards IO are tri-state until CS is activated and I can’t see any disturbance on them as I insert the card…
I read various comments on the requirement for pull-up resistors on the control lines but I think the consensus is “Not needed”. I also see designs with HC4050’s as level shifters But this design is all 3v3 (except for the I2C display).
Any thoughts or comment will be most welcome.
Regards, Martin
This may not be true. .. Try 'insert card' routine with MO/MI disconnected
Try some buffer chip. 74HC125, 74HC244, 74HC245 etc.
