Sorry I should have been more clear, I am using them both separately just to test them out, they do work independently.
I am doing these two things independently: -
Reading the state of the Busy Pin
Using the command myMP3.isPlaying()
Both of them give the correct answer most of the time, but intermittently give incorrect answers (as the code cycles around the main loop).
I think (noting that this is at the limits of my abilities) the code you linked to is ignoring the DF libraries completely and sending the serial control commands directly, so in that code "isPlaying" is just a local flag that he sets in his main loop?
I have with some trepidation opened up the DFPlayerMini_Fast.h library code. I think I can see that it sends a feedback request and a checksum value. Also see this datasheet extract: -
"we conducted an industrial level of optimization by adding frame checksum, retransmission, error handling, and other measures to significantly strengthen the stability and reliability of communication. " [DF Player data sheet]
So I assume from this that I can possibly assume it is sending and confirming commands and I don't need to do any of my own checking with the BUSY pin or myMP3.isPlaying() command? But I also notice that it has the option to turn feedback requests On/Off but I don't understand it enough to see where this is being selected?
I have posted the library code below in the hope that somebody who understands it can explain. Even though it is doing what I want right now I just want to make sure it doesn't start skipping commands once I pull it into my main project.
* @file DFPlayerMini_Fast.h
* This is the documentation for the YX5200-24SS MP3 player driver code for the
* Arduino platform. It is designed specifically to work with the
* <a href="https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299">
* DFPlayerMini breakout</a>
* These MP3 players use UART to communicate, 2 pins (TX + RX) are required
* to interface with the breakout. An external power supply and output amp
* improves the MP3 player's functionality. Also, see <a href="https://wiki.dfrobot.com/DFPlayer_Mini_SKU_DFR0299">
* the wiki</a> for more detailed wiring instructions.
* Written by Power_Broker as a hobby.
* None.
#pragma once
#include "Arduino.h"
#include "FireTimer.h"
@brief Namespace for constants
namespace dfplayer
/** Packet Values */
const uint8_t STACK_SIZE = 10; // total number of bytes in a stack/packet (same for cmds and queries)
const uint8_t SB = 0x7E; // start byte
const uint8_t VER = 0xFF; // version
const uint8_t LEN = 0x6; // number of bytes after "LEN" (except for checksum data and EB)
const uint8_t FEEDBACK = 1; // feedback requested
const uint8_t NO_FEEDBACK = 0; // no feedback requested
const uint8_t EB = 0xEF; // end byte
/** Control Command Values */
const uint8_t NEXT = 0x01;
const uint8_t PREV = 0x02;
const uint8_t PLAY = 0x03;
const uint8_t INC_VOL = 0x04;
const uint8_t DEC_VOL = 0x05;
const uint8_t VOLUME = 0x06;
const uint8_t EQ = 0x07;
const uint8_t PLAYBACK_MODE = 0x08;
const uint8_t PLAYBACK_SRC = 0x09;
const uint8_t STANDBY = 0x0A;
const uint8_t NORMAL = 0x0B;
const uint8_t RESET = 0x0C;
const uint8_t PLAYBACK = 0x0D;
const uint8_t PAUSE = 0x0E;
const uint8_t SPEC_FOLDER = 0x0F;
const uint8_t VOL_ADJ = 0x10;
const uint8_t REPEAT_PLAY = 0x11;
const uint8_t USE_MP3_FOLDER = 0x12;
const uint8_t INSERT_ADVERT = 0x13;
const uint8_t SPEC_TRACK_3000 = 0x14;
const uint8_t STOP_ADVERT = 0x15;
const uint8_t STOP = 0x16;
const uint8_t REPEAT_FOLDER = 0x17;
const uint8_t RANDOM_ALL = 0x18;
const uint8_t REPEAT_CURRENT = 0x19;
const uint8_t SET_DAC = 0x1A;
/** Query Command Values */
const uint8_t SEND_INIT = 0x3F;
const uint8_t RETRANSMIT = 0x40;
const uint8_t REPLY = 0x41;
const uint8_t GET_STATUS_ = 0x42;
const uint8_t GET_VOL = 0x43;
const uint8_t GET_EQ = 0x44;
const uint8_t GET_MODE = 0x45;
const uint8_t GET_VERSION = 0x46;
const uint8_t GET_TF_FILES = 0x47;
const uint8_t GET_U_FILES = 0x48;
const uint8_t GET_FLASH_FILES = 0x49;
const uint8_t KEEP_ON = 0x4A;
const uint8_t GET_TF_TRACK = 0x4B;
const uint8_t GET_U_TRACK = 0x4C;
const uint8_t GET_FLASH_TRACK = 0x4D;
const uint8_t GET_FOLDER_FILES = 0x4E;
const uint8_t GET_FOLDERS = 0x4F;
/** EQ Values */
const uint8_t EQ_NORMAL = 0;
const uint8_t EQ_POP = 1;
const uint8_t EQ_ROCK = 2;
const uint8_t EQ_JAZZ = 3;
const uint8_t EQ_CLASSIC = 4;
const uint8_t EQ_BASE = 5;
/** Mode Values */
const uint8_t REPEAT = 0;
const uint8_t FOLDER_REPEAT = 1;
const uint8_t SINGLE_REPEAT = 2;
const uint8_t RANDOM = 3;
/** Playback Source Values */
const uint8_t U = 1;
const uint8_t TF = 2;
const uint8_t AUX = 3;
const uint8_t SLEEP = 4;
const uint8_t FLASH = 5;
/** Base Volume Adjust Value */
const uint8_t VOL_ADJUST = 0x10;
/** Repeat Play Values */
const uint8_t STOP_REPEAT = 0;
const uint8_t START_REPEAT = 1;
@brief Class for interacting with DFPlayerMini MP3 player
class DFPlayerMini_Fast
public:
Stream* _serial;
/** Struct to store entire serial datapacket used for MP3 config/control */
struct stack {
uint8_t start_byte;
uint8_t version;
uint8_t length;
uint8_t commandValue;
uint8_t feedbackValue;
uint8_t paramMSB;
uint8_t paramLSB;
uint8_t checksumMSB;
uint8_t checksumLSB;
uint8_t end_byte;
} sendStack, recStack;
bool begin(Stream& stream, unsigned long threshold=500);
void playNext();
void playPrevious();
void play(uint16_t trackNum);
void stop();
void playFromMP3Folder(uint16_t trackNum);
void playAdvertisement(uint16_t trackNum);
void stopAdvertisement();
void incVolume();
void decVolume();
void volume(uint8_t volume);
void EQSelect(uint8_t setting);
void loop(uint16_t trackNum);
void playbackSource(uint8_t source);
void standbyMode();
void normalMode();
void reset();
void resume();
void pause();
void playFolder(uint8_t folderNum, uint8_t trackNum);
void volumeAdjustSet(uint8_t gain);
void startRepeatPlay();
void stopRepeatPlay();
void repeatFolder(uint16_t folder);
void randomAll();
void startRepeat();
void stopRepeat();
void startDAC();
void stopDAC();
void sleep();
void wakeUp();
bool isPlaying();
int16_t currentVolume();
int16_t currentEQ();
int16_t currentMode();
int16_t currentVersion();
int16_t numUsbTracks();
int16_t numSdTracks();
int16_t numFlashTracks();
int16_t currentUsbTrack();
int16_t currentSdTrack();
int16_t currentFlashTrack();
int16_t numTracksInFolder(uint8_t folder);
int16_t numFolders();
void setTimeout(unsigned long threshold);
void findChecksum(stack *_stack);
void sendData();
void flush();
int16_t query(uint8_t cmd, uint8_t msb=0, uint8_t lsb=0);
bool getStatus();
bool parseFeedback();
void printStack(stack _stack);
private:
FireTimer timoutTimer;
unsigned long _threshold;
/** MP3 response packet parsing states */
enum fsm {
find_start_byte,
find_ver_byte,
find_len_byte,
find_command_byte,
find_feedback_byte,
find_param_MSB,
find_param_LSB,
find_checksum_MSB,
find_checksum_LSB,
find_end_byte
fsm state = find_start_byte;
