I am using the queue list library from the playground Arduino Playground - QueueList Library i have a struct datatype and would like to insert it into it but its giving me an error.
This is what I want to do
QueueList queue;
error: template argument 1 is invalid
error: invalid type in declaration before ';' token
Is there a better way to approach to linking structs in a list.
I am using the queue list library from the playground Arduino Playground - HomePage i have a struct datatype and would like to insert it into it but its giving me an error.
You have a struct with some name. The struct keyword and the struct name need to be in the <>, not just the struct keyword.
Thank you, worked like a charm! I am assuming the reason for this is because each struct is a unique object, therefore the specific struct needs to be called.
Each struct is a specific type. To refer to that type you use 'struct' followed by the name of your struct.
It is common to use a typedef so that you can refer to that struct type without having to use the struct keyword; this is only a bit of syntactic sugar but means your struct behaves syntactically just like any of the basic types.
PeterH:
... which is not necessary in C++, which arduino uses.
Actually what I meant was how do I put my struct into the queue as a list entry or member using this library...
alternatively I decided to not go with the library and just use a standard linked list that contains my struct ... as this:
// device and linked list structure
struct linkedList {
int id;
char *name;
struct dev{
int hash;
unsigned long ts;
}dev;
struct linkedList *next;
}start, *node;
For some reason I was thinking that using this library would allow me to directly access the Nth element of the list/queue, however I think I was mistaken, hence my alternative approach since I have to traverse the list either way, less overhead not using the library.
You can access the nth element of a list, but not the nth element of a queue. A queue is like a line of people waiting to buy tickets to a soccer match. Which person in line should be dealt with next? The first person, obviously. Where should people get in line? At the end, of course.
I don't see the advantage of a struct in a struct.
