Hi all, I purchased an Arduino ONE and I can not install the drivers, I have Win7 Ultimate, can someone help me?
Thanks. ![]()
Thanks. ![]()
What happens?
Did you point the driver install process at the "driver" directory in the Arduino software folder (NOT the "FTDI USB Drivers" sub-directory)?
to connect my Arduino is recognized but does not install the drivers, to mark the path properties of the device drivers, said that a problem occurred and not installed, can you help me?
Thank you
Did you follow the Windows installing guide?
You might have to update the drivers from within the Device Manager.
I did, but not install the drivers.I've done in every way possible, and always says "a problem occurred .... ![]()
Thank
Can you please do this:
Press Windows key to open the start menu. Type "psr" without the quotes, then press and hold Shift+Control, then Enter. Click yes to the UAC prompt. Press the Record button in the problem recorder.
Try to update the driver from Device Manager, to show us the error and what are you doing. Then try to connect the arduino in another usb port to make the driver installation appear, point Windows to the arduino/drivers folder to look up for the driver.
Finally, click stop in the program recorder and attach that Zip file to this thread.
I reinstalled ths system anda ...nothing, I´ve arduino-0022 in Win 7 64 bit
add .rar!
Instal Fail Arduino.rar (580 KB)
jlindeh:
I reinstalled ths system anda ...nothing, I´ve arduino-0022 in Win 7 64 bitadd .rar!
Cant read Spanish.
Puedes intentar usar la opción de "Seleccionar desde una lista" y luego "Usar disco..." (en vez de búsqueda automática)
Es bien extraño lo que te sucede porque los archivos que usa arduino uno son archivos incluÃdos en Windows
Pues la verdad es que si es raro, por que intenté instalar los driver manual y automático y nada, y como debÃa reinstalar el equipo por otros problemas decidi probar de nuevo.. y nada...está tarde probaré automático a ver.
Gracias a todos ![]()
PS: Smeezekitty sorry for my english is awful..and sometimes I put more lyrics ![]()
eried:
Puedes intentar usar la opción de "Seleccionar desde una lista" y luego "Usar disco..." (en vez de búsqueda automática)Es bien extraño lo que te sucede porque los archivos que usa arduino uno son archivos incluÃdos en Windows
Nada no hay manera!! la verdad es que empiezo a dudar que sea el quipo y sea la version de mi Win 7, ya que tengo otro equipo de sobremesa en casa y tampoco puedo instalar los drivers. Gracias por vuestra paciencia e intentare probando en un dell antiguo que tengo le metere xp a ver que tal!
Un saludo y gracias
Solucionado.....Windows 7 32 bit, ya que en el 64 bit le faltaban 3 archivos dll por lo que no era posible instalarlo. Y aún habiendo descargado los dll no habÃa manera..... Gracias a todos
