install EasyTransfer arduino library
Hello,
After I have install the Easy Transfer library and load an example project that goes well.
But when I Built or verify the program I get a fatal error: EasyTransfer.h: No such file or directory
For install I have follow the next advice. ( I found it on de Bill Porter site )
To install the Library, open the zip file and transfer the EasyTransfer folder into your Arduino ‘libraries’ folder. Then follow the examples to add the code to your project.
I hope someone can give advice on how to solve this.
Thanks in advance.
Lenn
The structure is
Arduino/libraries/ in your user directory.
You will find the libraries in there, one directory per library.
Did you create a directory EasyTransfer under Arduino/libraries/ ? And next put the content of the zip in Arduino/libraries/EasyTransfer/ ?
Alternatively, there is an option somewhere in the menus to add a library from a zip file without girst opening the zip; I would try that first.
Click here to download madsci1016-Arduino-EasyTransfer-9941b63.zip
https://github.com/madsci1016/Arduino-EasyTransfer/zipball/master
Unpack the .zip file, usually by double-clicking on it. This will create a directory named "madsci1016-Arduino-EasyTransfer-9941b63".
Find your "Sketchbook location". In the Arduino IDE, select the "Preferences..." menu item. At the top of the resulting "Preferences" dialog you should see a setting for "Sketchbook location:". Mine is set to "/Users/john/Documents/Arduino" but that is on a Mac so yours might look different. Navigate to that location. In that directory there may already be a folder/directory named "libraries". If that doesn't exist, create it.
Inside the directory named "madsci1016-Arduino-EasyTransfer-9941b63" you will find a number of directories, including "EasyTransfer". Drag the "EasyTransfer" directory into the "libraries" directory.
In the Arduino IDE, select "Tools->Manage Libraries...". This will force the IDE to re-scan your libraries so it sees that EasyTransfer is there. When the progress bar at the bottom goes away, close the Library Manager dialog.
Select File->Examples->EasyTransfer->EasyTransfer_2Way_wPot_Example. It should compile without error. If that works, try your sketch again to see if the problem is fixed.
Hello,
It works many thanks.
Best regards,
Lenn
