Install ruby-gems through opkg breaks ruby
I am on OpenWRT version 1.5.3
root@Arduino:~# cat /etc/arduino/openwrt-yun-release
built=Mon Dec 4 16:38:21 UTC 2017
and when I install ruby through opkg (opkg install ruby), things are working fine. I can do ‘ruby bla.rb’ and it works, but after I install ruby-gems (opkg install ruby-gems), and do ‘ruby bla.rb’, I got the following error:
root@Arduino:~# gem
Traceback (most recent call last):
6: from internal:gem_prelude:2:in <internal:gem_prelude>' 5: from <internal:gem_prelude>:2:in require’
4: from /usr/lib/ruby/2.5/rubygems.rb:117:in <top (required)>' 3: from /usr/lib/ruby/2.5/rubygems.rb:1376:in module:Gem
2: from /usr/lib/ruby/2.5/rubygems.rb:1376:in require' 1: from /usr/lib/ruby/2.5/rubygems/specification.rb:17:in <top (required)>’
/usr/lib/ruby/2.5/rubygems/specification.rb:17:in `require’: incompatible library version - /usr/lib/ruby/2.5/mips-linux-gnu/stringio.so (LoadError)
Right now, I am on ruby version “ruby 2.5.1p57 (2018-03-29 revision 63029) [mips-linux-gnu]” and after removing the “ruby-gems” package, then things go back to normal, but I need ruby gem …
and when I do “file /usr/lib/ruby/2.5/mips-linux-gnu/stringio.so”, I got the following:
root@Arduino:~# file /usr/lib/ruby/2.5/mips-linux-gnu/stringio.so
/usr/lib/ruby/2.5/mips-linux-gnu/stringio.so: ELF 32-bit MSB shared object, MIPS, MIPS32 rel2 version 1 (SYSV), dynamically linked, corrupted section header size
Looks like this file stringio.so is corrupted! Could someone help?
