Installation of Arduino Wifi shield
Sir,
I am using Arduino Uno R3 (Barcode - 7//640152//110092//>) using Arduino sketch IDE version of 1.6.1 and an Arduino Wifi Shield R3 (Barcode - 8//058333//491158//>) with (MAC address 90-A2-DA-OF-DO-6C).
The wifi shield is not getting initialized when I m mounting it on the Arduino Uno board. Even on uploading the examples of Wifi module (ScanNetworks) .... the output on the serial monitor is displayed as "" Wifi Shield Not present".
Please help me out with this problem ....
1>What should be done at present ?????
2>Should I upgrade the firmware of the Shield???? or any other suggestion is welcome...
Insure the shield is connected correctly and the pins are inserted fully into the Uno.
This happens if you are using a pre-R3 Arduino and the wifi shield. Those require a jumper wire from the 5v socket to the IOREF socket on the shield. Do not do this if your Arduino is an R3 model.
I wish it were easier to merge cross-posted questions on different parts of the forum, but it isn't, so I deleted the others.
