Coding used:
Arduino coding used:
- Arduino2Max
- Send pin values from Arduino to MAX/MSP
- Arduino2Max.pde
- Latest update: September 2007
- Copyleft: use as you like
- by djmatic
- Based on a sketch and patch by Thomas Ouellet Fredericks tof.danslchamp.org
- Don't worry about the LED (which you can connect to digital 13 if you want) as it doesn't contribute anything new.
- Attach a potentiometer to 5v and Ground (two outer connections), and the sensor (central connection) to Analogue in 5.
- In fact, the code below reads ALL the analogue pins, so you can use any...
int x = 0; // a place to hold pin values
int led1Pin = 12; // LED #1 is connected to pin 12
int led2Pin[] = { 3, 4 }; // LED is connected to pin 12
int timer = 55; // The higher the number, the slower the timing.
int num_pins = 2;
int switchPin1 = 1;
int switchPin2 = 2; // switch is connected to pin 2
int val1; // variable for reading the pin status
int val2;
int i;
for (i = 0; i < num_pins; i++) // the array elements are numbered from 0 to num_pins - 1
pinMode(led2Pin*, OUTPUT); // set each pin as an output*
pinMode(led1Pin, OUTPUT); // Set the LED #1 pin as output
pinMode(switchPin1, INPUT); // Set the switch pin as input
pinMode(switchPin2, INPUT);
val1 = digitalRead(switchPin1);
if (val1 == LOW) { // check if the button is pressed
digitalWrite(led1Pin, HIGH);
delay(800);
digitalWrite(led1Pin, LOW); // turn LED #1 of
val2 = digitalRead(switchPin2);
if (val2 == LOW) { // check if the button is pressed
delay(800);
int i;
for (i = 0; i < num_pins; i++) { // loop through each pin...
digitalWrite(led2Pin*, HIGH); // turning it on,*
delay(timer); // pausing,
digitalWrite(led2Pin*, LOW); // and turning it off.*
for (i = num_pins - 1; i >= 0; i--) {
digitalWrite(led2Pin*, HIGH);*
delay(timer);
digitalWrite(led2Pin*, LOW);*
if (Serial.available() > 0){ // Check serial buffer for characters
if (Serial.read() == 'r') { // If an 'r' is received then read the pins
for (int pin= 0; pin<=5; pin++){ // Read and send analog pins 0-5
x = analogRead(pin);
sendValue (x);
for (int pin= 2; pin<=13; pin++){ // Read and send digital pins 2-13
x = digitalRead(pin);
sendValue (x);
Serial.println(); // Send a carriage returnt to mark end of pin data.
delay (5); // add a delay to prevent crashing/overloading of the serial port
void sendValue (int x){ // function to send the pin value followed by a "space".
Serial.print(x);
Serial.print(32, BYTE);
SC coding used:
s = Server.local;
b = Buffer.read(s,"recordings/box.wav");
c = Buffer.read(s, "recordings/help.wav");
) //booting local server and putting samples into buffers
p = ArduinoSMS("/dev/tty.usbserial-A4001nK8", 115200); ///connecting to Arduino
p.action = { |... msg| ~a = msg[2].postln; ~b = msg[1].postln;}; //making an argument out of the analog input that is read from the Arduino
//this coding has focused on the reading from analog 1 and 2, and have named them ~b and ~a
//these numbers is what the pottentiometer is controlling
fork {
1000.do {
p.send($r, $a, 0, 128);
0.06.wait;
) //the Routine that allows Supercollider to read and control the Arduino
SynthDef("box", { arg out=0,bufnum=0,rate=1;
Out.ar(out,
PlayBuf.ar(1, bufnum, BufRateScale.kr(bufnum)*rate, 1.0, 0.0, 1.0)
}).send(s);
SynthDef("help", { arg out=0,bufnum=0,rate=1;
Out.ar(out,
}).send(s);
//SynthDefs, which contain PlayBuf to play samples through
~box = Synth("box", [\bufnum,b.bufnum, \rate,~a]);
~help = Synth("help", [\bufnum,c.bufnum, \rate,~b]);
//Sythns playing selected buffers through the chosen SynthDef
g = Routine { loop { ~box.set(\rate, ~a.linlin(0, 1023, 0.01, 2.5)); (0.001).yield } }.play;
f = Routine { loop { ~help.set(\rate, ~b.linlin(0, 1023, 0.06, 4.5)); (0.001).yield } }.play;
) /// Routines which are loooping the Synths
p.close; //to close Aduino coding
