Installing BOTH Megacore and Mightycore
Arduino 1.6.5 used.
Is it possible to install BOTH cores? It seem that if I install the Megacore then the Mightycore is no longer there and viceversa.
Can more than 1 core be installed at the same time?
Did you do a Boards Manager installation or a Manual installation of the cores?
samperi:
is no longer there
What do you mean by "no longer there"? It doesn't show up in the Tools > Board menu?
I did a boards manager installation but if I install one pack then the board page shows the chip for that pack, trying to add another pack the same way gets rid of the above and I can only see the chips for the new pack.
By the way I also tried doing a change to the preferences file, at the moment I have both URLs separated by comma:
boardsmanager.additional.urls=https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json, https://mcudude.github.io/MegaCore/package_MCUdude_MightyCore_index.json
maybe it's not correctly done.
Both packs are installed (hmm can't just add screen shot here)
correct, I either see the mega chips or the mighty chips.
samperi:
That's correct, though it's easier to just do File > Preferences > Additional Boards Manager URLs. You do need to leave both URLs in that field. If you remove a URL then those boards no longer appear under Tools > Board.
So try the following:
  • With both URLs in the additional urls field, Open Tools > Board > Boards Manager
  • Check to be sure both packages are shown as installed
  • Close Boards Manager
  • Check Tools > Board to see if the boards for both packages appear
It works for me.
:frowning: it was a loose nut behind the keyboard..... :confused:
I had the wrong URL spelling for the 2nd URL https://mcudude.github.io/**MegaCore**/package_MCUdude_/**MightyCore**_index.json
it must have happened when I was trying things out yesterday. All working well and the check is in the mail.
Thank you very much.
