Installing esptool.
Recently and for the first time I purchased a couple ESP32's. Right away I found that I could successfully run a sketch on my Win10 laptop (Lenovo Yoga) without any changes to the environment, but the sketch just produces and endless rst loop on my desktop (where I prefer to work) .
I tried all the typical solutions I found with no joy. Then I made things worse by copying the 'preferences' txt file from my laptop to my desktop. I thought I had made a backup of the original desktop 'preferences' txt file but I must have fat-fingered that attempt.
Now, on my desktop all I get is 'esptool does not exist'.
I have tried to install it but am confused by what I have found and have not been successful.
fatfenders:
Please post the full and exact text of the error output.
pert:
As you have almost certainly determined at this point that I am something of a light-weight about this kind of stuff. That said, I played around with a a few things (not really sure of just what I was doing) while I was waiting for a response (BTW… Thank you!). After I read your reply I went back and recompiled to get the complete error message and… Waa-Laa, for reasons unkown to me, it compiled and executed just find (for the first time).
I guess I would rather be lucky than good… at least this time.
pert:
I was wrong. All my testing up until I started this thread was with the MELIFE unit. Today I received 2 of the HiLetgo units.
Below is the error message I get on my desktop with an
MELIFE ESP32 ESP-32S.
When I connect to a
HiLetgo ESP32 OLED WiFi Kit ESP-32 0.96 Inch Blue OLED Display
it works just fine.
So the HiLetgo works on both my laptop and desktop but the MELIFE only works on the laptop. Weird. Do you suppose there is something faulty with the MELIFE?
Error message on desktop with the MELIFE
ketch uses 663993 bytes (50%) of program storage space. Maximum is 1310720 bytes.
Global variables use 38084 bytes (11%) of dynamic memory, leaving 289596 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.0-dev
Serial port COM3
Traceback (most recent call last):
File “esptool.py”, line 3682, in
File “esptool.py”, line 3675, in main
File “esptool.py”, line 3329, in main
File “esptool.py”, line 263, in init
File "site-packages\serial_init
.py", line 88, in serial_for_url
File “site-packages\serial\serialwin32.py”, line 62, in open
serial.serialutil.SerialException: could not open port ‘COM3’: WindowsError(31, ‘A device attached to the system is not functioning.’)
Failed to execute script esptool
the selected serial port Failed to execute script esptool
does not exist or your board is not connected
Message I get on my desktop with the HiLetgo
Sketch uses 663993 bytes (50%) of program storage space. Maximum is 1310720 bytes.
esptool.py v3.0-dev
Serial port COM3
Connecting…
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 26MHz
MAC: 24:0a:c4:fc:9f:d0
Uploading stub…
Running stub…
Stub running…
Changing baud rate to 921600
Changed.
Configuring flash size…
Auto-detected Flash size: 8MB
Compressed 8192 bytes to 47…
Writing at 0x0000e000… (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds…
Hash of data verified.
Flash params set to 0x023f
Compressed 18656 bytes to 12053…
Writing at 0x00001000… (100 %)
Wrote 18656 bytes (12053 compressed) at 0x00001000 in 0.2 seconds (effective 793.9 kbit/s)…
Compressed 664112 bytes to 406023…
Writing at 0x00010000… (4 %)
Writing at 0x00014000… (8 %)
Writing at 0x00018000… (12 %)
Writing at 0x0001c000… (16 %)
Writing at 0x00020000… (20 %)
Writing at 0x00024000… (24 %)
Writing at 0x00028000… (28 %)
Writing at 0x0002c000… (32 %)
Writing at 0x00030000… (36 %)
Writing at 0x00034000… (40 %)
Writing at 0x00038000… (44 %)
Writing at 0x0003c000… (48 %)
Writing at 0x00040000… (52 %)
Writing at 0x00044000… (56 %)
Writing at 0x00048000… (60 %)
Writing at 0x0004c000… (64 %)
Writing at 0x00050000… (68 %)
Writing at 0x00054000… (72 %)
Writing at 0x00058000… (76 %)
Writing at 0x0005c000… (80 %)
Writing at 0x00060000… (84 %)
Writing at 0x00064000… (88 %)
Writing at 0x00068000… (92 %)
Writing at 0x0006c000… (96 %)
Writing at 0x00070000… (100 %)
Wrote 664112 bytes (406023 compressed) at 0x00010000 in 8.3 seconds (effective 637.7 kbit/s)…
Compressed 3072 bytes to 128…
Writing at 0x00008000… (100 %)
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1638.4 kbit/s)…
Leaving…
Hard resetting via RTS pin…
