Installing Microphython firmware with OpenMV fails
I have a brandnew Arduino Nano RP2040, and I want to flash the firmware, so I can use micropython. That doesn't work, it stops with the error message
PicoTool firmware update failed!
The command "picotool" terminated with exit code 249
DETAILS
/home/6ffm70/etc/OpenMV_inst/share/qtcreator/picotool/linux64/picotool load -x /home/6ffm70/.config/OpenMV/qtcreator/firmware/ARDUINO_NANO_RP2040_CONNECT/firmware.bin
No accessible RP2040 devices in BOOTSEL mode were found.
but:
Device at bus 1, address 30 appears to be a RP2040 device in BOOTSEL mode, but picotool was unable to connect
I'm using this guide:
My environment: Ubuntu 20.04 on a Lenovo laptop; OpenMV IDE 2.9.2
What happens?
I start the IDE,
connect the Arduino with a microUSB cable (tried several different),
press the boot button on the Arduino twice (now the LED is constantly green, the computer recognizes a mass storage device)
I press connect, a window appears as per manual
I press OK, above error meassage appears.
Is there a workaround to not use OpenMV? Can I drag and drop ARDUINO_NANO_RP2040_CONNECT/firmware.bin via my file browser?
