Hello!
I need help on how to install my MicroSD Card Adapter v1.0 11/01/2013 on my arduino rfid reader.
Link to RFID reader: Tutorial 12 for Arduino: RFID Card Reading – JeremyBlum.com
And here is a picture of the RFID reader:
Here is pictures of the MicroSD Card Adapter:
What pins should I using to connect the MicroSD card adapter to the rfid reader?
This is the code I am using:
//Jeremy Blum's Arduino Tutorial Series - Episode 12 - RFID Cards
//Sample Code - RFID Code Reading
//http://www.jeremyblum.com
//Some Code Adapted from http://www.cooking-hacks.com
//Code Updated on 1/21/2012 to comply with Arduino 1.0 Changes
byte data[5]; //For holding the ID we receive
int val = 0;
byte jeremy[5] = {0x3E,0x00,0xFC,0xBD,0x88};
byte david[5] = {0x3E,0x00,0xFC,0xFF,0xA5};
// Start serial port 19200 bps
Serial.begin(19200);
// Setting Auto Read Mode - EM4102 Decoded Mode - No password
// command: FF 01 09 87 01 03 02 00 10 20 30 40 37
Serial.write(0xFF); //Header
Serial.write(0x01); //Reserved
Serial.write(0x09); //Length (Command + Data)
Serial.write(0x87); //Command (0x87 sets auto mode behavior
Serial.write(0x01); //Data 1: Enable Auto-Read
Serial.write(0x03); //Data 2: Mode – Parity decoded – Manchester RF/64
Serial.write(0x02); //Data 3: Total number of block to be read (2)
Serial.write((byte)0x00); //Data 4: No password expected
Serial.write(0x10); //Data 5: Password byte 1
Serial.write(0x20); //Data 6: Password byte 2
Serial.write(0x30); //Data 7: Password byte 3
Serial.write(0x40); //Data 8: Password byte 4
Serial.write(0x37); //Checksum
while(Serial.available()>0)
Serial.read();
Serial.println("RFID module started in Auto Read Mode, Waiting for Card...");
val = Serial.read();
while (val != 0xff)
{ //On Successful read, first byte will always be 0xFF
//we already read the header (0xff)
Serial.read(); // reserved
Serial.read(); // length
Serial.read(); // command (indicates tag data)
data[0] = Serial.read(); // we read data 1
data[1] = Serial.read(); // we read data 2
data[2] = Serial.read(); // we read data 3
data[3] = Serial.read(); // we read data 4
data[4] = Serial.read(); // we read data 5
Serial.read(); // checksum
// Indentify RFID Card
boolean j_card = true;
boolean d_card = true;
Serial.print("Card found - Code: ");
for (int i=0; i<5; i++)
if (data[i] < 16) Serial.print("0");
Serial.print(data[i], HEX);
//cross-check
if (data[i] != jeremy[i]) j_card = false;
if (data[i] != david[i]) d_card = false;
if (j_card) Serial.println("Hello Jeremy!");
else if (d_card) Serial.println("Hello David!");
else Serial.println("Not Recognized! Get out of Here!");
And my other problem is that I want to store every RFID tag, that is used on my RFID reader, inside an MicroSD card. So when I use for exeple a tag on the rfid, the arduino will store the data from the tag inside the sd card. When I put the SD card inside my pc it will show a .txt file with the RFID tag
information in it.
So I wanna know what codes I shall use, where I need to put the code and what I need to change in order to make it work?
Thank you in advance!!
