Installing unzip package in Yun or How do I install zip file
Hi NoblePepper or Sonnyyu,
How can I unzip files in yun. It is not allowing me to install opkg install unzip.
or
should I use any other tool to install zip file on to a directory in Yun.
Sorry this may be trivial,
Thanks and appreciate for your help
Regards
BRE
opkg update
opkg list |grep unzip
unzip - 5.52-1 - InfoZIP's unzip program. With the exception of multi-volume archives (ie, .ZIP files that are split across several disks using PKZIP's /& option),  this can handle any file produced either by PKZIP, or the corresponding  InfoZIP zip program.
opkg install unzip
BTW, this is public forum you could utilize it to put multiple horses on the race track instead of only two. :stuck_out_tongue:
Sonnyyu,
Super. Super
Installed unzip
Karma++
Regards,
BRE
Sonnyyu,
Quick clarification.
Before posting the message: I tried 1 and 4 step
1 opkg update
2. opkg install unzip
But this did not install unzip
what does step 2 and 3 ( outlined by you) will do
opkg list | grep unzip
Please clarify,
Thanks
BRE
BREL:
That looks in the updated package list for the unzip program description
That is the resulting output of step 3) on his Yun. If you do not get that output (or one very close to that), then installing unzip in step 4 will obviously fail....
hth,
Ralf
