Installing wavesoft/CClib
Hi Guys
I am trying to install the wavesoft/CCLib sketch manually in windows .When I try to compile the sketch I get the error message
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\johnm\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\johnm\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\johnm\OneDrive\Документы\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10819 -build-path C:\Users\johnm\AppData\Local\Temp\arduino_build_542371 -warnings=none -build-cache C:\Users\johnm\AppData\Local\Temp\arduino_cache_426882 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\johnm\CCLib-master\CCLib-master\Arduino\CCLib\Examples\CCLib_proxy\CCLib_proxy.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\johnm\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\johnm\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\johnm\OneDrive\Документы\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -ide-version=10819 -build-path C:\Users\johnm\AppData\Local\Temp\arduino_build_542371 -warnings=none -build-cache C:\Users\johnm\AppData\Local\Temp\arduino_cache_426882 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -verbose C:\Users\johnm\CCLib-master\CCLib-master\Arduino\CCLib\Examples\CCLib_proxy\CCLib_proxy.ino
Using board 'nano' from platform in folder: C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\johnm\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\johnm\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\johnm\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\johnm\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "C:\\Users\\johnm\\AppData\\Local\\Temp\\arduino_build_542371\\sketch\\CCLib_proxy.ino.cpp" -o nul
Alternatives for CCDebugger.h: []
ResolveLibrary(CCDebugger.h)
  -> candidates: []CCLib_proxy:50:10: fatal error: CCDebugger.h: No such file or directory
 #include <CCDebugger.h>
compilation terminated.
exit status 1
When I try to unzip it
via arduino >sketch>include>add zip library i get the error message
As always any help woud be greatly  appreciated.
Thanks oldguyjn
exit status 1
Specified folder/zip file does not contain a valid library
