instant help
//Timer1 Mode 10 PWM to ICR1
//Dual pin 200KHz PWM generator
//47.5% duty cycle 125ns dead band between pulses
pinMode(9, OUTPUT); //output A
pinMode(10, OUTPUT); //output B
TCCR1A = 0; //clear timer registers
TCCR1B = 0;
TCNT1 = 0;
//ICR1 and Prescaler sets frequency
//no prescaler .0625 us per count @ 16Mh
//80 counts x .0625 = 5 us = 200Khz
TCCR1B |= _BV(CS11); //no prescaler
ICR1 = 20000;//PWM mode counts up and back down for 80 counts
OCR1A = 10000; //Pin 9 match
//output A set rising/clear falling
//Rise at TCNT 21 upslope, High 38 counts, Fall at TCNT 21 downslope
//47,5% Duty Cycle Pulse centered on TCNT 40. High 38 Low 42
TCCR1A |= _BV(COM1A1) | _BV(COM1A0); //output A set rising/clear falling
OCR1B = 8000; //Pin 10 match
//output B clear rising/set falling
//Fall at TCNT 19 upslope, Low 42, Rise at TCNT 19 downslope
//47.5% Duty Cycle Pulse centered on TCNT 0. High 38 Low 42
TCCR1A |= _BV(COM1B1); //output B clear rising/set falling
TCCR1B |= _BV(WGM13); //PWM mode with ICR1 Mode 10
TCCR1A |= _BV(WGM11); //WGM13:WGM10 set 1010
void loop() {}
i am using this program to achieve two pwm signals can i get both signals at 25% duty cycles and 25hz frequency with desired phase shift between them. your response will be helpful please
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :slight_smile:
I read your post. I didn't get any instant help. I am disappointed.
[code]
  TCCR1B = 0;
  TCNT1 = 0;
[/code]
Can i get both signals at 25% duty cycles and 25hz frequency with desired phase shift between them? your response will be helpful please
any help will be appreciated
CLASHINGHARSH:
Help with what? You haven’t asked a question.
CLASHINGHARSH:
Good for you. Seems like everything is working as you want. I'm out.
CLASHINGHARSH:
Response to what? What is your question?
Montmorency:
i want 25hz with 25% dutycycle
25Hz?
You could do that in software.
