Hi frndz
I need to find instantaneous values of AC current
I found a code for ACS 712 on another post and changed it a bit because i only need instantaneous current values
the readings i got for a particular device were like the the following
almost positive extreme readings (6.22 Ampere)
then 0.01 somthng
then negative extreme readings (- 5.92 Ampere)
nd the pattern continues like this
nd i expected to get very close readings (like 1.00 A then 1.01A then 1.02A) but this didnt happen but it should since i mean measuring current after 400 micro seconds
Plz tell me what is the prob in the following code
sampleinterval = 0.1 sec
num of samples = 250
sample interval = 400us
const int currentPin = 3;
const unsigned long sampleTime = 100000UL;
const unsigned long numSamples = 250UL;
const unsigned long sampleInterval = sampleTime/numSamples;
const int adc_zero = 510;
float currentAcc = 0;
unsigned long prevMicros = micros() - sampleInterval ;
if (micros() - prevMicros >= sampleInterval)
int adc_raw = analogRead(currentPin) - adc_zero;
currentAcc = (float)currentAcc *(50.0/1024.0);
prevMicros += sampleInterval;
Serial.println(currentAcc);
