Instantating a class - I think?
Looking at the example DS3231_Simple.ino from the "Rtc by Makuna" library, I see this code:
16 /* for normal hardware wire use below */
17 #include <Wire.h> // must be included here so that Arduino library object file references work
18 #include <RtcDS3231.h>
19 RtcDS3231 <TwoWire> Rtc(Wire);
20 /* for normal hardware wire use above */
Would anyone mind talking me through what is happening at line 19?
I guess that we are instantiating a new object of class: RtcDS3231? But what is happening with the following two expressions?
Regards, ~M
read about Class templates
[color=red]RtcDS3231[/color] <[color=blue]TwoWire[/color]> [color=green]Rtc[/color]([color=purple]Wire[/color]);
you have a "templatized" class [color=red]RtcDS3231[/color]
The type to use for the template is TwoWire
the name of the instance you create is
Rtc
and the constructor for that class takes a parameter which is [color=purple]Wire[/color]
EDIT: actually found some documentation here directly in the github
