Instantiating an object in a class with parameters
I'm trying to make a telnet server class to be used in multitasking, while I'm unable to instantiate ESPTelnet object with port parameter passed to constructor, while the same syntax works in the main file without class
ESPTelnet telnet(PORT); GIVES ERROR 'PORT' is not a type
class telnetTask : public Task {
 public:
    const int PORT = 23;
  protected:
    ESPTelnet telnet (PORT);  //------------------ GIVES ERROR: 'PORT' is not a type
what should be the correct syntax to initiate ESPTelnet object in a class
Seems to me you haven't put up enough to have any idea what could be wrong. Lets see your class. And why is this call protected? Who you protecting it from?
-jim lee
Use an Initializer List. See case #3.
jimLee:
Seems to me you haven’t put up enough to have any idea what could be wrong. Lets see your class. And why is this call protected? Who you protecting it from?
-jim lee
well, I just used to do this as an OOP concept, while changing this to private or public didn’t do any change
If I didn’t pass PORT parameter to the function, it gives another error in calling object funcions “No Matching function for call to 'ESPTelnet::onConnect”
#include "WiFiManager.h"
#include "ESPTelnet.h"
#include <Arduino.h>
#include <Scheduler.h>
#define SERIAL_SPEED    9600
#define PORTAL_TIMEOUT  10 * 60 // seconds
#define AP_NAME         "MY CAPTIVE PORTAL"
#define AP_PASSWORD     ""
  private:
    WiFiManager wifiManager;
    ESPTelnet telnet;
    IPAddress ip_addr;
    void connectToWifi() {
      // wifiManager.resetSettings();  // this will delete all credentials
      wifiManager.setDebugOutput(false);
      wifiManager.setConfigPortalTimeout(PORTAL_TIMEOUT);
      wifiManager.setAPCallback([] (WiFiManager * myWiFiManager) {
        Serial.println("- No known wifi found");
        Serial.print("- Starting AP: ");
        Serial.println(myWiFiManager->getConfigPortalSSID());
        Serial.println(WiFi.softAPIP());
      // enable autoconnect
      if (!(AP_PASSWORD == "" ?
            wifiManager.autoConnect(AP_NAME) :
            wifiManager.autoConnect(AP_NAME, AP_PASSWORD))
        Serial.println("- Failed to connect and hit timeout");
        ESP.reset();
        // known wifi found & connected
      }  else {
        ip_addr = WiFi.localIP();
        String mac_addr = WiFi.macAddress();
        String wifi = WiFi.SSID();
        Serial.println("- WiFi: " + wifi);
        Serial.println("- IP: " + ip_addr.toString());
    void setupTelnet() {
      if (telnet.begin()) {
        telnet.onConnect(onTelnetConnect);
        telnet.onConnectionAttempt(onTelnetConnectionAttempt);
        telnet.onReconnect(onTelnetReconnect);
        telnet.onDisconnect(onTelnetDisconnect);
        Serial.println("- Telnet is running. Connect to Telnet using:");
        Serial.println("telnet " + ip_addr.toString());
        // could not create server
        Serial.println("- Failed to create Telnet server. Is device connected to WiFi?");
        delay(10000);
        ESP.reset();
    // (optional) callback functions for server
    void onTelnetConnect() {
      Serial.print("- Telnet: ");
      Serial.print(telnet.getIP());
      Serial.println(" connected");
      telnet.println("\nWelcome " + telnet.getIP());
      telnet.println("(Use ^] + q  to disconnect.)");
    void onTelnetDisconnect() {
      Serial.println(" disconnected");
    void onTelnetReconnect() {
      Serial.println(" reconnected");
    void onTelnetConnectionAttempt() {
      Serial.print(telnet.getLastAttemptIP());
      Serial.println(" tried to connected");
      // setup serial output
      Serial.begin(SERIAL_SPEED);
      while (!Serial) {
        delay(10);
      Serial.println("\n\nTelnet Test");
      connectToWifi();
      setupTelnet();
    int counter = 0;
      telnet.loop();
      telnet << ".";            // same as: telnet.print(".");
      if (counter++ % 10 == 0) telnet.println();
gfvalvo:
I tried to understand how to Apply it to my code, but I couldn't get it done, any TIP
This compiles without error or warning:
class ESPTelnet
  public:
    ESPTelnet(int port);
class telnetTask
  public:
    telnetTask() : telnet(telnetTask::PORT) {}
  protected:
    ESPTelnet telnet;  //------------------ GIVES ERROR: 'PORT' is not a type
void setup() {}
void loop() {}
johnwasser:
class ESPTelnet
  public:
class telnetTask
  public:
protected:
void setup() {}
void loop() {}
Works perfectly, Thanks, you made my day
