Instead of add to array, only add last
I followed a Simon Says tutorial
It has different modes.
Default = the simon says game
If you press the green button on startup it’s a battle version of the game.
If you press the yellow button on startup a small song is played.
I added the following.
If you press the red button it’s the simon says game and changed default mode into a baby mode.
The game should be almost the same as simon says, but only without a sequence.
So only 1 random led (and sound) and if you press this button, only a new random button will be shown. Until the currentMove = ROUNDS_TO_WIN
I used the same code as the memory game, cause the game is very similar, but am not able to make it so that it does not “add” a button to the sequence.
boolean play_baby(void)
  randomSeed(millis()); // Seed the random generator with random amount of millis()
  gameRound = 0; // Reset the game to the beginning
  while (gameRound < ROUNDS_TO_WIN)
    baby_moves(); // Add a button to the current moves, then play them back
    playMoves(); // Play back the current game board
    // Then require the player to repeat the sequence.
    for (byte currentMove = 0 ; currentMove < gameRound ; currentMove++)
      byte choice = wait_for_button(); // See what button the user presses
      if (choice == 0) return false; // If wait timed out, player loses
      if (choice != gameBoard[currentMove]) return false; // If the choice is incorect, player loses
    delay(1000); // Player was correct, delay before playing moves
  return true; // Player made it through all the rounds to win!
  Serial.print("You've won");
The baby moves code is
void baby_moves(void)
  byte newButton = random(0, 4); //min (included), max (exluded)
  // We have to convert this number, 0 to 3, to CHOICEs
  if(newButton == 0) newButton = CHOICE_RED;
  else if(newButton == 1) newButton = CHOICE_GREEN;
  else if(newButton == 2) newButton = CHOICE_BLUE;
  else if(newButton == 3) newButton = CHOICE_YELLOW;
  gameBoard[gameRound++] = newButton; // Add this new button to the game array
  Serial.println(gameRound);
Hope somebody can help me with this problem so I have a nice and easy game for my baby :slight_smile:
I think this should do it…
while (gameRound < 1)
Instead of…
Edit or maybe…
gameBoard[0] = newButton; // Add this new button to the game array
Instead of…
And then…
  int babyRound = 0;
  while (babyRound < ROUNDS_TO_WIN)
    babyRound++;
    if (choice != gameBoard[0]) return false; // If the choice is incorect, player loses
I will try it tomorrow and get back to you :slight_smile:
Many tnx.
@pcbbc (and other off course)
I see some changes in the game that looks very promising, but we’re not quite there yet.
Hope you still have a tip for me.
In Serial mode I get the message that the baby game is started:
BABY MODE ENABLED
0
But there’s no random led :slightly_frowning_face:
The game does seem to work. Because tt will give the timeout after 3 seconds and the game start again.
I also think a random led is choosen, but it’s not show. If I hit for example the red button every time the game starts again, sometimes I get a good hit. I also see in serial monitor that there is a good hit because I get
BABY MODE ENABLED
0
0 <----- good hit
When there is not a good hit, I get
BABY MODE ENABLED
0
BABY MODE ENABLED
0
BABY MODE ENABLED
0
BABY MODE ENABLED
0
When the random led will be showing, I believe it’s complete. And it should be extra nice if in serial mode the actual gameRound will be print, instead of only zero’s :slight_smile: :slight_smile: :slight_smile:
Many tnx hope you understand my problem
update.
The game seem to work.
I also serial print the random button
  Serial.println(newButton);
I did a complete came with pressing the right button based on the number in serial monitor.
If the playback will be working, it's complete, only I don't know how :slight_smile: :slight_smile: :slight_smile:
A small update,
I believe the playBabymoves function is not correct.
void playBabyMoves(void)
    toner(gameBoard[currentMove], 150);
    // Wait some amount of time between button playback
    // Shorten this to make game harder
    delay(150); // 150 works well. 75 gets fast.
Hope somebody know what code to put in.
