INSTRUCTING ARDUINO TO RECALL A PREVIOUSLY GIVEN VALUE
You seem to be confusing declaring (or creating) a variable with assigning a value (or changing) to a variable. If the variable is declared (i.e. int distance=0;) at the top of the code (outside setup() or loop()), its value can be assigned anywhere in the code (i.e. distance=55).
You need to create/declare the variable first (at the top) and then assign whatever value you want later e.g. distance=Serial.Read().
This has now moved on to http://arduino.cc/forum/index.php/topic,97230.0.html
The threads could be merged if a mod is watching.
I hate it when that happens.
Thanks for the heads up.
int var;
void function()
    var = 42;
void setup(){}
void loop(){}
whats the issue? post code
i would like my function to change the meaning of the variable 'distance'
variables are just values, meanings of that value is what you hold in your head... post code
