Instruction IF could not understand
Hi guys,
i could not follow up this problem ...
int Var = 0;
Serial.begin (115200);
if (Var == 1)
  Serial.println ("VAR 111111111");
  delay (500);
if (Var == 0);
  Serial.println ("VAR 0000000000");
  delay (500);
Give me this result:
![Result VAR IF Statement|690x249](upload://p2NSWaqQYOoShUvz7wlfFiIUzJ2.png)
Please could someone explain me why, because of Var = 0, program is reading IF statement with condition if (Var == 1)...
Thanks for help
Regards
if (Var == 0);
What is that semicolon doing there ?
Thank you !!!
I tried again, and it works without semicolon,
there is no error in the program ...
Thanks
Regards
Do you understand why the semicolon caused a problem ?
no !
The semicolon ends the statement that is executed when the if returns true. You will note that there is actually no statement to be executed
However, the code in the curly brackets will be executed unconditionally whatever the result of the test
Sounds clear for me,
thanks for explanations,
Regards
