im using a INA125P to amplify a load cell. the load cell output goes to a 16 bit ADC (measurin differential voltage) that communicates with an UNO. the Uno, adc, and amplifier share a common ground. its a 2000lb load cell with a 3 mv/v slope. Granted its oversize for what i need but it still should work. i am using a single sided power supply (can make it a dual with resistors if needed...) and have tried both configurations in the manual (figure 1 and 6) but neither work as expected. I believe its because figure 1 needs a dual sided power supply. The configuration in figure 6 does work but doesn't work as i expect. It has the following attributes:
- when i change Rg, the zero load offset changes significantly. the voltage will go from -2v to -1.5v if i increase the gain.
- if i go to a super high gain the gain doesn't actually increase.
- if i use a 10 ohm resistor the output peak to peak doesn't go up.
- the noise is insanely bad. granted i am not using best of power supplies but i was under the impression this amp had great noise rejection.
- the noise can be as bad as 5% of the peak to peak change when adding 50 lbs.
- noise only gets worse when adding the cap between Vin and ground.
- i am supplying 14v to pins 1 and 2. pin 4 gets power from pin 14. i am measuring voltage between pin 11 and ground. pin 12 is grounded. pin 10 to 11 is shorted. Rg between 8 and 9. S+ and S- to 6 and 7 respectively. Bridge excitation powered by pin 4 and ground. 3 to ground. 5 either to ground or 4 depending on the setup (figure 1 vs 6)
i was having issues while using a proto board so i made a pcb and things improved. noise is better but is still an issue. i have a pcb for both layouts.
any ideas? i know there is a lot here but i suspect i am using the amp outside its intended range?
