int , if,else if question
int main()
int x = 1;
int y = x++;
if (y >= 1)
digitalWrite(2, LOW);
else if (y >= 2)
digitalWrite(4, LOW);
else if (y >= 3)
digitalWrite(6, LOW);
else if (y >= 4)
digitalWrite(7, LOW);
else if (y >= 5)
digitalWrite(8, LOW);
digitalWrite(9, LOW);
The light does not turn on. help me
Main() is hidden from use. Normally setup() and loop() are what you want if using arduino.
Also if y=5 all those if statements will be true. Is that what you want?
Look into using a switch statement.
ysu4638:
int main()
int x = 1;
int y = x++;
if (y >= 1)
else if (y >= 2)
else if (y >= 3)
else if (y >= 4)
else if (y >= 5)
“reverse” your value checking -
check for highest value first.
