Can someone help me understand how is this program working when int is not even defined.
In the first iteration x = 0, so 0 will be printed because it is less than 3. In the next iteration x = x + foo() meaning x = 0 + q + 1. Therefore, in this second iteration it will checked q+1 < 3 but we don't know what is q then how will second iteration will be done?
#include <stdio.h>
int foo (int q) {
int x = 1;
return (q + x);
int main (){
int x = 0;
while (x < 3) {
printf ("%i ", x);
x = x + foo(x);
I typed this above code in the compiler and I was able to get 0 1. I don't know understand how?
Thanks, but I still habe problem understand which line is executing after a certain line of code. I am newbie. If we change the variable to a in the foo and b in the main probably then it might make sense to make. Can you explain by considering a and b as variable?
I had some idea of local and global variable in python but in this particular code I was confuse with the same name of two variables and also because I didn't know how is exactly the code executes either line by line as in Python or other way around.
