hello everybody , my potentiometer give values from 0-1023 , and i wanted to the value to be duplicated , i can duplicate the the printed value but i wanted the sensor value to be duplicated, here i attached the code .
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
