I am trying to convert an int to a char to be displayed as ASCII but I cannot figure out how to get it to work. I am sure there is an answer to this already but I cannot find one that works. Any help would be greatly appreciated. Thank you
int b
char display_b
if (vertical <= 450){
b++;
delay(200);
if (b >= 10){
b = 0;
display_b = b;
alpha4.writeDigitAscii(0, display_b);
alpha4.writeDisplay();
int a = 65; // ASCII equivalent of A
Serial.write(a);
or
int a = 9;
Serial.write(a + '0');
or
int a = 9;
Serial.write(a + 48);
What is it that you are writing to, ie, what is alpha4 and which library is it using ?
I am using an Adafruit 7-segment LED display with featherwings. It uses the Adafruit_GFX and Adafruit_LEDBackpack libraries. A link to the product is below
int bb;
char display_bb [10] = {};
void setup ()
Serial.begin(19200);
Serial.println("ready. . .");
void loop ()
bb = 9;
itoa(bb, display_bb, 10);
Serial.println(display_bb);
bb = 1001;
bb = 2002;
delay(2000);
Thank you for the reply. I modified this code to send display_bb to my display but the char is still empty so it doesn't display anything. Would you have any advice on how to change this?
I'm not sure how that could be - I ran it and the Serial.println executes as per plan.
I guess
is supposed to make digit_0 register a char value
and
is supposed to update the output register
I have no experience with that library.
these are using a HT16K33.
I have a library for the HT16K33 which is based on the common Print.h interface:
https://werner.rothschopf.net/201909_arduino_ht16k33.htm
it can print integers with a simple
alpha4.print(b);
and all other types supported by Print.h
I found a way to get it to work. Not the nicest looking solution but it works for what I need it to do. Thanks for all your help everyone
// look at these websites
// https://learn.adafruit.com/adafruit-7-segment-led-featherwings/arduino-usage
// https://forum.arduino.cc/t/using-an-adafruit-7-segment-display-with-i2c-backpack/462141
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_AlphaNum4 alpha4_blue = Adafruit_AlphaNum4(); // changed name; might be able to use two at a time this way
Adafruit_AlphaNum4 alpha4_red = Adafruit_AlphaNum4();
// pins for joystick
const int VERT = 0; // analog A0
const int HORIZ = 1; // analog A1
const int SEL = 2; // digital S2
int vertical, horizontal, select;
int score; // number to manipulate with vertical input for RED
int score_b; // number to manupulate with horizontal input for BLUE
int slot_select; // slot select variable; so score can be displayed
char display_score_0, display_score_1, display_score_2, display_score_3; // score to be displayed RED
char ds_b_0, ds_b_1, ds_b_2, ds_b_3; // score to be displayed BLUE
// make the SEL line an input
pinMode(SEL, INPUT_PULLUP);
// set up serial port for output
slot_select = 0; // give slot select initial value
alpha4_red.begin(0x71); // pass in the address - RED(0x71), BLUE(0x72)
alpha4_red.writeDigitRaw(3, 0x0);
alpha4_red.writeDigitRaw(0, 0xFFFF);
alpha4_red.writeDisplay();
delay(200);
alpha4_red.writeDigitRaw(0, 0x0);
alpha4_red.writeDigitRaw(1, 0xFFFF);
delay(200);
alpha4_red.writeDigitRaw(1, 0x0);
alpha4_red.writeDigitRaw(2, 0xFFFF);
delay(200);
alpha4_red.writeDigitRaw(2, 0x0);
alpha4_red.writeDigitRaw(3, 0xFFFF);
delay(200);
alpha4_red.clear();
// blue display
alpha4_blue.begin(0x72); // pass in the address - RED(0x71), BLUE(0x72)
alpha4_blue.writeDigitRaw(3, 0x0);
alpha4_blue.writeDigitRaw(0, 0xFFFF);
alpha4_blue.writeDisplay();
delay(200);
alpha4_blue.writeDigitRaw(0, 0x0);
alpha4_blue.writeDigitRaw(1, 0xFFFF);
delay(200);
alpha4_blue.writeDigitRaw(1, 0x0);
alpha4_blue.writeDigitRaw(2, 0xFFFF);
delay(200);
alpha4_blue.writeDigitRaw(2, 0x0);
alpha4_blue.writeDigitRaw(3, 0xFFFF);
delay(200);
alpha4_blue.clear();
char displaybuffer[4] = {' ', ' ', ' ', ' '};
int a; // integer for slot_select
int r_1, r_2, r_3; // intergers for red score
int b_1, b_2, b_3; // integers for blue score
void loop_1() {
if (select == HIGH) {
Serial.println('WORKING'); }
// scroll down display
displaybuffer[0] = displaybuffer[1];
displaybuffer[1] = displaybuffer[2];
displaybuffer[2] = displaybuffer[3];
displaybuffer[3] = displaybuffer[0];
// set every digit to the buffer
alpha4_red.writeDigitAscii(0, displaybuffer[0]);
alpha4_blue.writeDigitAscii(0, displaybuffer[0]);
alpha4_red.writeDigitAscii(1, displaybuffer[1]);
alpha4_blue.writeDigitAscii(1, displaybuffer[1]);
alpha4_red.writeDigitAscii(2, displaybuffer[2]);
alpha4_blue.writeDigitAscii(2, displaybuffer[2]);
alpha4_red.writeDigitAscii(3, displaybuffer[3]);
alpha4_blue.writeDigitAscii(3, displaybuffer[3]);
delay(200);
// read all values from the joystick
vertical = analogRead(VERT); // will be 0-1023
horizontal = analogRead(HORIZ); // will be 0-1023
select = digitalRead(SEL); // will be HIGH (1) if not pressed, and LOW (0) if pressed
// print out the values
Serial.print("vertical: ");
Serial.print(vertical, DEC);
Serial.print(" horizontal: ");
Serial.print(horizontal, DEC);
Serial.print(" select: ");
Serial.println(slot_select); }
else {
Serial.println("PRESSED!"); }
// // // // button for slot selection to write score
if (select == LOW){ // if select is pressed, a increases
a++;
slot_select = a;
delay(200);}
if (slot_select >= 4){ // set_slot select back to 0
slot_select = 0;
a = 0;}
else { // sets slot_select to a if slot_select <= 0
slot_select = a;}
///////////increment score BLUE: from horizontal
/////////////////////////////// slot 1
if (horizontal >= 750 && slot_select == 1){
b_1++;
score_b = b_1;
delay(200);}
if (horizontal <= 200 && slot_select == 1){
b_1--;
score_b = b_1;
delay(200);}
if (b_1 >= 10 || b_1 <= 0){
b_1 = 0;}
/////////////////////////////// slot 2
if (horizontal >= 750 && slot_select == 2){
b_2++;
score_b = r_2;
delay(200);}
if (horizontal <= 200 && slot_select == 2){
b_2--;
score_b = b_2;
delay(200);}
if (b_2 >= 10 || b_2 <= 0){
b_2 = 0;}
/////////////////////////////// slot 3
if (horizontal >= 750 && slot_select == 3){
b_3++;
score_b = b_3;
delay(200);}
if (horizontal <= 200 && slot_select == 3){
b_3--;
score_b = b_3;
delay(200);}
if (b_3 >= 10 || b_3 <= 0){
b_3 = 0;}
/////////// increment score RED: from vertical. watch the direction of the Joystick!!
if (vertical <= 250 && slot_select == 1){
r_1++;
score = r_1;
delay(200);}
if (vertical >= 800 && slot_select == 1){
r_1--;
score = r_1;
delay(200);}
if (r_1 >= 10 || r_1 <= 0){
r_1 = 0;}
if (vertical <= 250 && slot_select == 2){
r_2++;
score = r_2;
delay(200);}
if (vertical >= 800 && slot_select == 2){
r_2--;
score = r_2;
delay(200);}
if (r_2 >= 10 || r_2 <= 0){
r_2 = 0;}
if (vertical <= 250 && slot_select == 3){
r_3++;
score = r_3;
delay(200);}
if (vertical >= 800 && slot_select == 3){
r_3--;
score = r_3;
delay(200);}
if (r_3 >= 10 || r_3 <= 0){
r_3 = 0;}
//////////////////////////////////////////////////////////////////////////////// shitty way to do it?
if (a == 0){display_score_0 = ' ';}
if (a == 1){display_score_0 = '.';}
if (a == 2){display_score_0 = '-';}
if (a == 3){display_score_0 = '/';}
//////////////red display scores
if (r_1 == 0){display_score_1 = '0';} // r_1
if (r_1 == 1){display_score_1 = '1';}
if (r_1 == 2){display_score_1 = '2';}
if (r_1 == 3){display_score_1 = '3';}
if (r_1 == 4){display_score_1 = '4';}
if (r_1 == 5){display_score_1 = '5';}
if (r_1 == 6){display_score_1 = '6';}
if (r_1 == 7){display_score_1 = '7';}
if (r_1 == 8){display_score_1 = '8';}
if (r_1 == 9){display_score_1 = '9';}
if (r_2 == 0){display_score_2 = '0';} // r_2
if (r_2 == 1){display_score_2 = '1';}
if (r_2 == 2){display_score_2 = '2';}
if (r_2 == 3){display_score_2 = '3';}
if (r_2 == 4){display_score_2 = '4';}
if (r_2 == 5){display_score_2 = '5';}
if (r_2 == 6){display_score_2 = '6';}
if (r_2 == 7){display_score_2 = '7';}
if (r_2 == 8){display_score_2 = '8';}
if (r_2 == 9){display_score_2 = '9';}
if (r_3 == 0){display_score_3 = '0';} // r_3
if (r_3 == 1){display_score_3 = '1';}
if (r_3 == 2){display_score_3 = '2';}
if (r_3 == 3){display_score_3 = '3';}
if (r_3 == 4){display_score_3 = '4';}
if (r_3 == 5){display_score_3 = '5';}
if (r_3 == 6){display_score_3 = '6';}
if (r_3 == 7){display_score_3 = '7';}
if (r_3 == 8){display_score_3 = '8';}
if (r_3 == 9){display_score_3 = '9';}
//////////////blue display scores
if (b_1 == 0){ds_b_1 = '0';} // b_1
if (b_1 == 1){ds_b_1 = '1';}
if (b_1 == 2){ds_b_1 = '2';}
if (b_1 == 3){ds_b_1 = '3';}
if (b_1 == 4){ds_b_1 = '4';}
if (b_1 == 5){ds_b_1 = '5';}
if (b_1 == 6){ds_b_1 = '6';}
if (b_1 == 7){ds_b_1 = '7';}
if (b_1 == 8){ds_b_1 = '8';}
if (b_1 == 9){ds_b_1 = '9';}
if (b_2 == 0){ds_b_2 = '0';} // b_2
if (b_2 == 1){ds_b_2 = '1';}
if (b_2 == 2){ds_b_2 = '2';}
if (b_2 == 3){ds_b_2 = '3';}
if (b_2 == 4){ds_b_2 = '4';}
if (b_2 == 5){ds_b_2 = '5';}
if (b_2 == 6){ds_b_2 = '6';}
if (b_2 == 7){ds_b_2 = '7';}
if (b_2 == 8){ds_b_2 = '8';}
if (b_2 == 9){ds_b_2 = '9';}
if (b_3 == 0){ds_b_3 = '0';} // b_3
if (b_3 == 1){ds_b_3 = '1';}
if (b_3 == 2){ds_b_3 = '2';}
if (b_3 == 3){ds_b_3 = '3';}
if (b_3 == 4){ds_b_3 = '4';}
if (b_3 == 5){ds_b_3 = '5';}
if (b_3 == 6){ds_b_3 = '6';}
if (b_3 == 7){ds_b_3 = '7';}
if (b_3 == 8){ds_b_3 = '8';}
if (b_3 == 9){ds_b_3 = '9';}
////////// write to display RED
alpha4_red.writeDigitAscii(0, display_score_0);
alpha4_red.writeDigitAscii(1, display_score_1);
alpha4_red.writeDigitAscii(2, display_score_2);
alpha4_red.writeDigitAscii(3, display_score_3);
////////// write to display BLUE
alpha4_blue.writeDigitAscii(0, display_score_0);
alpha4_blue.writeDigitAscii(1, ds_b_1);
alpha4_blue.writeDigitAscii(2, ds_b_2);
alpha4_blue.writeDigitAscii(3, ds_b_3);
//alpha4.writeDigitRaw(0, 0x0); // Send - character position [first value], data value [second value] - to the display buffer
//alpha4.writeDigitRaw(1, a); // Send - character position [first value: left to right -> 0,1,2,3], data [second value] - to the display buffer.
//alpha4.writeDisplay(); // Write the display buffer to the physical display
Your code contains a lot of repeating lines like this:
Characters in C are just integers, they can also be added. In order to convert an integer from 0 to 9 into the corresponding symbol, just add its value to the symbol '0':
if (r_1 >= 0 && r_1 <= 9) display_score_1 = r_1 + '0';
This line is completely equivalent to the nine lines above
Do the same for r_2, r_3 and b_1 - b_3 and your code will become significantly shorter
