Int var1 = 0.5 + func(array); doesn't work to correct rounding?
I am converting a float to an integer and want the rounding to be correct. I am trying to do this by adding 0.5 before putting the value into the integer variable (averageFrontTemp) but for some reason I can't figure out, it just doesn't happen? It keeps rounding down.
Could anyone please tell me what might be wrong? Thanks.
Code excerpt:
averageFrontTemp = 0.5 + samplesToTemp(samplesFront);
Entire code:
// Thermistor Example #3 from the Adafruit Learning System guide on Thermistors
// https://learn.adafruit.com/thermistor/overview by Limor Fried, Adafruit Industries
// MIT License - please keep attribution and consider buying parts from Adafruit
#include <EEPROM.h> // Need this to store settings after power down
#define DEBUG 1 // value is 1 to enable debugging serial printing
#if DEBUG == 1
#define DEBUG(x) Serial.print(x)
#define DEBUGLN(x) Serial.println(x)
#else
#define DEBUG(x)
#define DEBUGLN(x)
#endif
// which analog pins to use with thermistors
#define THERMISTORPINFRONT A0
#define THERMISTORPINBACK A0 // A1
#define THERMISTORPINARMS A0 // A2
#define THERMISTORPINLEGS A0 // A3
// which high power pins to use to drive MOSFETS
#define HEATERMOSFETFRONT D5
#define HEATERMOSFETBACK D6
#define HEATERMOSFETARMS D2
#define HEATERMOSFETLEGS E4
// which digital pins to use for buttons
#define BUTTONSET D7 // D7
#define BUTTONMINUS D8 // D8
#define BUTTONPLUS D9 // D9
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the resistor used to make a potential divider with the thermistor
#define SERIESRESISTOR 10000
// how frequently to read the thermistors and act on readings
const unsigned long temperatureResponseInterval = 5000;
const unsigned long thermistorReadShortInterval = 10;
// debounce setting for the buttons
unsigned long debounceDelay = 50;
// places to store average measured temperature
byte averageFrontTemp; // might make these arrays for the thermal runaway safety feature
byte averageBackTemp; // it will use a marker to keep track of which entry was the latest
byte averageArmsTemp; // reading and maybe? the remainder function to convert this into the
byte averageLegsTemp; // oldest reading for the thermal runaway prevention
// places to store user-selected temperature settings
byte tempSettingFront = 45;
byte tempSettingBack = 45;
byte tempSettingArms = 45;
byte tempSettingLegs = 45;
// arrays to store thermistor readings prior to conversion to an average temperature
int samplesFront[NUMSAMPLES];
int samplesBack[NUMSAMPLES];
int samplesArms[NUMSAMPLES];
int samplesLegs[NUMSAMPLES];
// flags for timing of tasks
bool thermistorSamplingFlag = false;
bool thermistorSamplingCompleteFlag = false;
bool mosfetControlFlag = false;
// button states - need unsigned long lastDebounceTime = 0; for each switch
int buttonStateSet;
int lastButtonStateSet = HIGH;
int buttonStateMinus;
int lastButtonStateMinus = HIGH;
int buttonStatePlus;
int lastButtonStatePlus = HIGH;
void setup(void) {
  analogReference(EXTERNAL); // connect 3.3 V to AREF and to thermistor potential divider
  pinMode(HEATERMOSFETFRONT, OUTPUT);
  pinMode(HEATERMOSFETBACK, OUTPUT);
  pinMode(HEATERMOSFETARMS, OUTPUT);
  pinMode(HEATERMOSFETLEGS, OUTPUT);
  pinMode(BUTTONSET, INPUT_PULLUP);
  pinMode(BUTTONMINUS, INPUT_PULLUP);
  pinMode(BUTTONPLUS, INPUT_PULLUP);
void loop(void) {
  thermistorSamplingTimerTask();
  thermistorSamplingTask();
  thermistorSampleAveragingTask();
  mosfetControlTask();
// thermistor sampling is blocked when the sampling flag is false: this function sets the flag to
// true every temperatureResponseInterval seconds
void thermistorSamplingTimerTask() {
  static unsigned long previousMillis = 0;
  if (currentMillis - previousMillis < temperatureResponseInterval) {
    return;
  thermistorSamplingFlag = true;
  return;
void thermistorSamplingTask() {
  static byte index = 0;
  if (thermistorSamplingFlag == false) {
    return;
  // at the "thermistorReadShortInterval
  if (millis() -  previousMillis < thermistorReadShortInterval) {
    return;
  previousMillis = millis();
  // take NUMSAMPLES samples
  samplesFront[index] = analogRead(THERMISTORPINFRONT);
  samplesBack[index] = analogRead(THERMISTORPINBACK);
  samplesArms[index] = analogRead(THERMISTORPINARMS);
  samplesLegs[index] = analogRead(THERMISTORPINLEGS);
  index = (index + 1) % NUMSAMPLES; // this resets index to 0 when array contains NUMSAMPLES values
  if (index == 0) { // when index is reset to 0, it's because the array is full and complete
    thermistorSamplingFlag = false; // sampling can now stop for a while
    thermistorSamplingCompleteFlag = true; // this lets the next stage of the loop begin
    return;
void thermistorSampleAveragingTask() {
  // check whether array is full - this flag is set to true when the array is full
  if (thermistorSamplingCompleteFlag == false) {
    return;
  // do the averaging here
  averageFrontTemp = 0.5 + samplesToTemp(samplesFront); // adding 0.5 prevents it always rounding down when turning float to int
  DEBUG("Front: ");
  DEBUG(averageFrontTemp);
  DEBUGLN("°C");
  averageBackTemp = 0.5 + samplesToTemp(samplesBack);
  DEBUG("Back: ");
  DEBUG(averageBackTemp);
  DEBUGLN("°C");
  averageArmsTemp = 0.5 + samplesToTemp(samplesArms);
  DEBUG("Arms: ");
  DEBUG(averageArmsTemp);
  DEBUGLN("°C");
  averageLegsTemp = 0.5 + samplesToTemp(samplesLegs);
  DEBUG("Legs: ");
  DEBUG(averageLegsTemp);
  DEBUGLN("°C");
  thermistorSamplingCompleteFlag = false; // reset this flag so sampling can begin again
// function for turning list of resistance measurements into temperature reading
byte samplesToTemp(int samplesZone[]) {
  float average = 0;
  // average all the samples out
  for (byte index = 0; index < NUMSAMPLES; index++) {
    average += samplesZone[index];
  average /= NUMSAMPLES;
  DEBUG("Average analog reading ");
  DEBUGLN(average);
  // convert the value to resistance
  average = 4095 / average - 1;               // value 4095 is for LGT8F's 12-bit ADC; 1023 for Arduino
  average = SERIESRESISTOR / average;
  DEBUG("Thermistor resistance ");
  DEBUGLN(average);
  float steinhart;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;                         // convert absolute temp to C
  DEBUG("Temperature ");
  DEBUG(steinhart);
  DEBUGLN(" *C");
  return steinhart;
void mosfetControlTask() {
  // check flag to see if we're ready to set MOSFET outputs
  if (mosfetControlFlag == false) {
    return;
  // compare temperature readings to thermostat settings and switch MOSFETs accordingly
  if (averageFrontTemp < tempSettingFront) digitalWrite(HEATERMOSFETFRONT, HIGH);
  else digitalWrite(HEATERMOSFETFRONT, LOW);
  if (averageBackTemp < tempSettingBack) digitalWrite(HEATERMOSFETBACK, HIGH);
  else digitalWrite(HEATERMOSFETBACK, LOW);
  if (averageArmsTemp < tempSettingArms) digitalWrite(HEATERMOSFETARMS, HIGH);
  else digitalWrite(HEATERMOSFETARMS, LOW);
  if (averageLegsTemp < tempSettingLegs) digitalWrite(HEATERMOSFETLEGS, HIGH);
  else digitalWrite(HEATERMOSFETLEGS, LOW);
I'm far from a coding expert but I believe a float to int simply truncates. If you need rounding you could do it manually or use one of the Arduino round functions.
Looks like this function doesn't return float...
It returns byte.
In other words, it's already truncated when the function returns the value.
Yes, I see now; the problem was in a different part of the code than where I was fiddling. Thanks very much.
