[int variable] was not declared in this scope
I defined variables in the void setup section:
int PumpPin=13;
In the loop section:
digitalWrite(PumpPin,HIGH);
Compilation error: 'PumpOn' was not declared in this scope
Make sure all the names match, and that all are declared.
You are likely missing
byte PumpOn;
at the top of your sketch.
If you declare within setup then the variable is local to setup and won’t “work” outside of it .
You need to declare it before setup , then it will be global everywhere .
Compilation error: ‘PumpOn’ was not declared in this scope
PumpPin is not the same as PumpOn.
I think we need to see your code to give you a proper answer?
Thanks... Tom... :slight_smile:
