INT
Hello, is there a way to do an integer that lasts throughout the whole code? For example when you use and int in setup you can't use it again. If there a type of integer that would allow me to do it again?
Just put it at the top of your code, that will make it a global variable :)
http://arduino.cc/en/Reference/scope
guix: Just put it at the top of your code, that will make it a global variable :)
Thank you!
NP :)
After re-reading your post, I realize you may be interested by the "static" keyword, example:
  static int i;
  i++;
Using static, the i variable will not be reset to 0 every loop()
