Hi
Please help. I can't find the error in this.
I have an old "grandfathers clock" 2m tall. I am trying to detect how many "gongs/hit on the bell" when the clock is 1, 2, 3 ... half past etc. When the clock is i.e. 5 the distance in time between the hits are app 1.5 sec.
I am using INT0 for triggering my code using an Arduino Uno rel 3
Variables modified during the interrupt are declared volatile.
Below you can find a log of what is happening.
My problem can be seen in line 20 "2 - one Gong only: 1 Activated twice - and then all this happens"
and the next three lines.
I do not understand why it can go into "2" without have been in "1" before.
The sensor is a Hall element with fair hardware filtering. The nature of the code should also help on debouncing.
Interrupts are disabled during the if-sentences even though it should not be needed.
it does not help anyway.
I am sure someone out there can teach me.
Many thank you in advance.
Please see code below - and logfile very below
Knock on a bell caught on INT0
the purpose of this code is to detect the hammer in an old "Grandfather's clock"
to get how many hits (3 hits at 3 o'clock) I dont care if only 1 hit i.e. half past and at 1 o'clock
bellHit is run each time the bell is hit.
First if sentence is run each time the bell is hit because WakeUp was set true in the ISR. Timeout reset
The second if sentence is run if only one hit before Bell timeout
The third if sentence is run after at least 2 hits and the timeout has run out
volatile int bellCount = 0;
volatile int WakeUp = false;
unsigned long gongInterval = 2000; // Bell timeout
volatile unsigned long previousMillis = 0;
attachInterrupt(0, bellHit, FALLING);
Serial.println("First shot on a statemachine with INT0 from the bell in a big clock");
if (WakeUp == true){ // First if sentence
noInterrupts(); // should not be needed
previousMillis = millis();
WakeUp = false;
Serial.print("1 Interrupt - Gongs: ");
Serial.println(bellCount);
interrupts(); // should not be needed
if ((unsigned long)(millis() - previousMillis) >= gongInterval & bellCount == 1){ // Second if sentence
Serial.print("2 - one Gong only: ");
bellCount = 0;
if ((unsigned long)(millis() - previousMillis) >= gongInterval & bellCount >= 2){ // Third if sentence
Serial.print("3 - 2 or more: " );
// do the work needed, when the clock is 2 or more.
bellCount = 0;
void bellHit() // ISR
noInterrupts();
WakeUp = true;
bellCount = bellCount + 1;
interrupts();
logfile:
1 Interrupt - Gongs: 1 Activated once
2 - one Gong only: 1 OK
1 Interrupt - Gongs: 1 Activated twice
1 Interrupt - Gongs: 2
3 - 2 or more: 2 OK
3 - 2 or more: 2 again OK
1 Interrupt - Gongs: 0
2 - one Gong only: 1 only one is counted up - should have been two
More examples below - usually OK
1 Interrupt - Gongs: 3
3 - 2 or more: 3
1 Interrupt - Gongs: 4
3 - 2 or more: 4
1 Interrupt - Gongs: 5
1 Interrupt - Gongs: 6
1 Interrupt - Gongs: 7
3 - 2 or more: 7
