Inteference between CC3000 WIFI Shield and LCD
Hardware
Arduino UNO with CC3000 WIFI shield...
... the one which plugs directly into the UNO. The LCD is a standard 16 pin LCD running on a shift register 74HC595 (as shown here in this tutorial Arduino Playground - LiquidCrystal Library).
Pins used
The LCD is using pins 11 and 13 along with a latch pin of A5. The WIFI shield is not modified and I don't see how that would be possible anyway.
Library
Issue
Random inference between the WIFI board and the LCD causing corruption of the LCD text. I'm a newb at this but after reading into it, I believe the issue is related to the fact that both the LCD and the CC3000 both utilise the bus with channels 11 (MOSI I think) and 13 (SPI). Is there anyway for a beginner to get these 2 devices to play nicely? As I can't easily modify the WIFI shield, is there a way to modify the LCD somehow so that it doesn't need to use these pins or get them to share the bus as they should?
Please help!
This particular issue turned out to be an error with my wire mapping. This is compatible!
I'm working with the same components. Did you resolve it? Did you replace either WiFi shield or LCD shield?
Here the sample code I'm using:
#include <LiquidCrystal.h>
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
// These are the interrupt and control pins
#define ADAFRUIT_CC3000_IRQ 3 // MUST be an interrupt pin!
// These can be any two pins
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Use hardware SPI for the remaining pins
// On an UNO, SCK = 13, MISO = 12, and MOSI = 11
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIVIDER); // you can change this clock speed
#define WLAN_SSID "[redacted]" // cannot be longer than 32 characters!
#define WLAN_PASS "[redacted]"
// Security can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
#define WLAN_SECURITY WLAN_SEC_WPA2
#define IDLE_TIMEOUT_MS 3000 // Amount of time to wait (in milliseconds) with no data
// received before closing the connection. If you know the server
// you're accessing is quick to respond, you can reduce this value.
// What page to grab!
#define WEBSITE "www.adafruit.com"
#define WEBPAGE "/testwifi/index.html"
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int readkey;
uint32_t ip;
void setup(void)
lcd.begin(16,2);
lcd.clear();
lcd.print("Hello, CC3000!");
lcd.setCursor(0, 1);
lcd.print("Free RAM: "); lcd.print(getFreeRam(), DEC);
/* Initialise the module */
lcd.print("Initializing...");
if (!cc3000.begin())
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Error");
//Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
// Optional SSID scan
// listSSIDResults();
lcd.print("Connecting to ");
lcd.print(WLAN_SSID);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
lcd.clear();
lcd.print("Failed!");
while(1);
lcd.clear();
lcd.print("Connected!");
void loop(void)
