I was doing some research into integer division on the Arduino Uno, and trying to determine the fastest methods of solving division.
In readings, I came across this post.
I grabbed and modified the sketch that Nick Gammon posted in reply #4, the ultimate aim being to compile a list of the computations that I need to perform, with their timings.
Here is my modified sketch:
#define DATATYPE byte
#define OPERATION i / j
volatile DATATYPE x=0;
volatile DATATYPE y=0;
//volatile DATATYPE j=7;
unsigned long time;
unsigned long loop_time;
void setup ()
Serial.println ();
time = micros();
for (DATATYPE i = 1; i < 101; i++) {
//for (DATATYPE j = 1; j < 101; j++) {
for (DATATYPE j = 56; j < 57; j++) {
y++;
} // end of for j
} // end of for i
loop_time = micros() - time;
Serial.print("Loop baseline Completion time: ");
Serial.print(loop_time);
Serial.print(" ");
time = micros();
y++;
x = OPERATION;
} // end of for j
} // end of for i
Serial.print("Completion time: ");
Serial.print(time);
Serial.print(" Operation time: ");
time = time - loop_time;
Serial.println(time);
} // end of setup
void loop() {}
Problem #1: You are not only measuring the OPERATION you are also measuring the amount of time it takes for the interrupt service routine to shuffle bytes out the serial port.
Problem #2: You may also be measuring the time it takes for the timer 0 overflow interrupt to run.
I have made no such assumption.
I was looking at methods I could use in my code to produce faster results.
It was just an Anomaly that I noticed while playing with that particular sketch
The timing was to determine a couple of things for myself.
If you looked at the thread I got this sketch from in the first place, you can see that there are speed differences based on the data type used.
I wanted to find the timings for different divisions to see if they could be solved quickly enough for my application.
Regardless of why I am testing, (or even if I should test), I would still be interested to know why the timings on those two particular numbers take a lot less time than the timings on other numbers.
Hi
I'm sorry but I'm still not clear what you're suggesting.
Unless I've totally misunderstood how interrupts on the Arduino Uno work, nothing in my code blocks an interrupt, and nothing that an interrupt does will terminate a those loops prematurely
An ISR could run any time, but I can't see how I would be timing timer0 overflow interrupt only in the case of j=3 and j=57.
Robin2:
Avoid using division. If at all possible use a combination of right shifts and multiplication.
And if you are working with integers make sure to avoid overflow or underflow - time isn't everything.
From some tests I did a while ago IIRC an unsigned long division takes much the same time as a float division - which rather surprised me.
...R
Hi
This was one of the reasons that brought start investigating.
Most of the numbers I'll be dealing with are signed long integers, and a comment I remember seeing regarding the length of time re long vs float division got me to try some comparisons.
Hence the code...
Hence the anomaly...
Hence the question
Why should the datatype for that loop counter change when you want to consider the time for divisions of different datatypes.
I don't see the point of changing the values used in the division calculation. If you suspect that the values involved in the calculation have an effect on the duration of the calculation then try some specific different calculations to test that hypothesis.
Separately, I reckon if I was trying to figure out the time of a calculation I would measure it over 1000 or 10,000 iterations
I would also do some untimed tests to make sure that the answers to the calculations are correct.
So in the case of 57/58 (and I suppose 3/4)
The compiler is optimising the code to use reciprocal multiplication and bit shifting
instead of unsigned division
When I first started out with this, I found the sketch that Nick Gammon posted.
I just copied it and ran it before starting to play with it.
I wanted, ultimately to test signed and unsigned longs, but I like to make small changes and
run to see that I've not made (too great) mistakes.
anyway, I made some changes to the loops, and decided that I wanted to test dividing by one number.
I chose a number at random, which was 57.
The difference in what I got, to what Nick reported was enough for me to play some more with this section, wanting to understand what was going on, rather than to ignore it.
Robin2:
As I said, I make small changes and run. My first aim was to change the loops and timings to suit my eventual needs.
Robin2:
...R
Again, small changes and test to see if things work
The answers (in themselves) are not terribly important at this stage. I just wanted to see how long a division would take.
A small sample is quite fine for me at the moment, just to give me an idea of what was going on.
What it has shown is that the compiler apparently optimises specific denominators into reciprocal multiplication and bitshifts. That may be useful to know and exploit (If I was clever enough to do so)
Robin2:
I think you are missing my point. IMHO the datatype used for the loop counter should be quite independent from the datatype you are testing.
Ah, I (think I) get what you're saying.
The counters serve both as counters and as Dividend and Divisor.
Remember, this was taken from a previous test and is being modified to suit.
The code is simple and easy to read. One define will change what is being tested. Neat!
Robin2:
I would not be content testing code that does not give sensible answers. The compiler might be cleverer than you and optimize out some code.
...R
True. But again, at the time of posing this question, I was more interested in the results of the timing rather than the results of the operation. All I wanted was to find out how long dividing one number by another number took. The compiler did optimise out code, but it turned out to be serendipitous.
darrob:
You are making the assumption that the two are independent. If I was in your shoes I would like to see proof of that .
